Cooler for Ryzen 5 3600 in Summer
Guardian Jade
I live in California and the summers are hot. I am using the stock cooler with the AMD Ryzen 5 3600 overclocked to 4 ghz and my case is a NZXT H510 Elite. I am looking for a good aio cooler under $150 for my cpu. Do you have any suggestions?
Should just be able to get away with a basic Hyper 212, otherwise might as well get the NZXT AIO, since it'll match your case.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
I don't know much about AIOs but I'm fairly sure that a Noctua NH-D15 could cool down a furnace in hell (and it costs less than your budget 😉 )
MAIN PC: CPU: AMD Ryzen 5 2400G | Motherboard: Gigabyte GA-AB350-Gaming | RAM: 16Gb DDR4 Patriot Viper 4 3200 | GPU: XFX RX580 4Gb GTS | Case: Sharkoon S25-W | Storage: M.2 NVME Adata Gammix S10 128Gb + SATA SSD WD Blue 1Tb | ODD: LG GH24NSD1 | PSU: Seasonic Core GM-500 | Display: AOC I2490PXQU | Cooler: Wraith Stealth | Keyboard: Logitech K120 | Mouse: Logitech B100 | Sound: the usual integrated Realtek | OS: Windows 10 Pro 64bit
RETRO PC: CPU: AMD Athlon 64 2800+ | Motherboard: Gigabyte GA-K8VM800M | RAM: 2Gb DDR 800 | GPU: ATi Radeon 9600 Pro 128Mb | Case: Tacens Anima AC4500 | Storage: IDE WD Blue 80Gb + IDE DVD-RW drive + floppy drive | Sound: Terratec 128i ESS Solo-1 PCI | OS: Windows 98 SE + Windows XP SP3 + Linux Bionic Pup 32
HTPC: CPU: AMD Athlon 3000G | Motherboard: AsRock B450M-HDV R4.0 | RAM: 16Gb DDR4 G.Skill Aegis 3200 | Case: Aerocool CS-101 | Storage: SATA SSD Silicon Power A55 256Gb | ODD: LG blu-ray WH14NS40 | OS: Windows 10 Pro 64bit
If you really want to use aio then go for corsair h115i
Arctic Liquid Freezer II  240mm and up
I edit my posts more often than not
Hyper 212 Black edition cheaper works and you can spend the extra dough on steam or upgrading your pc
