Looking For Premium Gaming Monitor at or less than $1000 CAD
Solved by Stahlmann,
If you want to go all out on your budget, get an OLED: LG 27GS95QE-B 27.0" 2560 x 1440 240 Hz Monitor (27GS95QE-B) - PCPartPicker
OLED ensures you will have the best possible image quality and motion performance in most situations. Unless you're doing your daily work on the same monitor, the risk of burn in should be negligible.
Featured Topics
Steve_6502 ·
Dedayog ·
Posted in General Discussion0 -
ng8743 ·
Posted in Troubleshooting2 -
Mnemonically_impared ·
DxD ·
Posted in Troubleshooting6 -
4
5
