Tomorow I will need to go to school again and... I sit whit a... hm... a bit dumb guy... a few days ago he asked me how much did my PC cost, I answered, he send me a few pics of MONITORS for like 150€ an I told him that my monitor cost about 150€ too... Then he said: wHy Do YoU nEeD a Pc If YoU hAvE a MoNiToR?¿?
https://linustechtips.com/topic/1310765-help-please/
Ok? Many people don’t know the difference between a monitor and the actual computer. Instead of ridiculing someone for not knowing something why not teach them so they know for the future?
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1310765-help-please/#findComment-14523711
Because then you can't get internet points!
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1310765-help-please/#findComment-14523734
-= Moved to Off-Topic =--
Mind where your post.
He is probably thinking of AOE pcs.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1310765-help-please/#findComment-14523936
7 hours ago, urbanzerdin said:
I tought of that too, but... he said he was thinking about MONITORS and showed them to me again
Some people don't know the difference between monitors and computers, others don't know that you can connect more than one monitor to a PC.
Also, next time you should use the following thread ;
https://linustechtips.com/topic/34813-experiences-with-non-techies/
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1310765-help-please/#findComment-14525204
AOE pc?  What's that stand for?  Always thought it was AIO PC -- all-in-one.
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
https://linustechtips.com/topic/1310765-help-please/#findComment-14525326
Thought it might have been the thing where you shift your hand, but then it would be AOP or AUI.
Unless the keyboard layout is different.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1310765-help-please/#findComment-14525330
wat do AOP and AUI mean
#Muricaparrotgang
https://linustechtips.com/topic/1310765-help-please/#findComment-14525336
Sometimes you'll be typing and one hand will be off a row.
If you move one key row left or right for "IO" you get "OP" or "UI".
"OE" is not an option, so I don't think it was a hand-shift mistake unless the keyboard layout is different.
https://linustechtips.com/topic/1310765-help-please/#findComment-14525338
OHHHHHHH!!!!!
I get it.  I get things.  I'm smart.
#Muricaparrotgang
https://linustechtips.com/topic/1310765-help-please/#findComment-14525342
OHHHHHHH!!!!!
I believe that you're smart.
I'm gullible like that.
bonus points if you know where I'm quoting from
https://linustechtips.com/topic/1310765-help-please/#findComment-14525344
He's trolling you and you're letting him.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1310765-help-please/#findComment-14525383
Hmmm. Not sure about that. Some people really are that ignorant about technology.
My advice to the OP is to share your knowledge. You like tech and they are asking you about it, So share some of your knowledge. I personally enjoy talking tech with people who are curious about it.
https://linustechtips.com/topic/1310765-help-please/#findComment-14525811
