4-pin to 8-pin PSU issue?
Solved by mariushm,
The 4 pin CPU connector is rated for up to around 200 watts of power (2 pairs x 12v x 9A per pair = 12x18 = ~ 216 watts)
The 8 pin CPU connector is rated for 4 pairs x 7A per pair x 12v = 336 watts (each pair is de-rated for safety from 9A to 7A due to having so many wires so close together in the connector)
Your 3400g consumes around 50-60 watts, and maybe peaks at around 80 watts or so in heavy cpu benchmarks.
Basically, even if you abuse the CPU and overclock it a bit, you'll barely reach HALF of the capabilities of the 4 pin CPU connector. You're perfectly safe with just the 4 pin CPU connector from your power supply - adapters will only add potential failure points and they're not needed for your system.
