5 minutes ago, xxx68 said:
Hello guys, i am not sure where to place radiator from CPU aio i can place it on front bottom as in picture or on the front top. What Is better option?
Front-Top.
The pump is located in the CPU cold plate, which is the highest point in the loop when the radiator is at the front-bottom. Air will always move to the highest point in a liquid container, whether it be a water bottle, piping system in a house, or n AIO. This means any air in the loop will be in the pump, which is bad for a water pump since it uses the fluid itself for things like lubrication which is importnat to keep the pump lasting a long time.
By placing the radiator at the Front-Top, you move the "highest point" to the radiator instead, ensuring the pump always is moving water, not air. For less noise, position the tubes coming off the radiator on the bottom side. (This portion is less important but some people will yell this because they think it's the ONLY way to put it else "you're doing it wrong")
12 minutes ago, TVwazhere said:
Front-Top.
Thanks a lot so just to be sure. Do I have it positioned properly now ? Thx
Yep, that's totally fine!
