High GPU Hot spot temps
Go to solution Solved by So Corse,
1 hour ago, So Corse said:
i'll try this now, and ill post the after result then, thank you
So, it's better, alot better
Thank you so much for the help bro, it was a really bad bad thermal paste placement/bad contact i wiped and applied a new one,
1 hour ago, Agall said:
You'd be using any generic thermal paste, ideally non-conductive. If you live nearby any place that sells computer hardware, even Best Buy, they'll have some basic stuff or Corsair branded stuff.
People get way too deep into min-maxing thermal paste. As long as its non-conductive and thermal paste, its fine. Otherwise you could run into an issue I ran into back in 2014 or so with Artic Silver 5 and have a small strand shorting the die to one of the caps around the die on the substrate that prevented the machine from POSTing.
Just be careful removing the cooler to not mess up the thermal pads too much. Ideally you're mitigating the damage to them so you can reuse them. On a DDR6 card like the 6700XT, even if you have to put the pieces back on, it should be fine. You'll more than likely tear some of them or they'll just tear on their own, but just play puzzle pieces with the parts so they're still mostly whole.
I have a question regarding GPU Hot spot temps, i am running a RX 6700 XT, and my hot spot temps is 90-100°C+, while the overall of the gpu is 79°C, is that like bad? or maybe there is something wrong with my GPU?
This is while running The Last of Us (In the Main menu) and opening Opera GX, i don't know if this occur just recently or for a long time, i just notice this when i was opening HWMonitor, should i change thermal paste or maybe it's normal? But while its on idle or i don't utilize my GPU its more or less the same with overall GPU temps on 50-60°C. I've uploaded a images regarding the temps of both my CPU and GPU so that it maybe of some use.
Thank you in advance.
https://linustechtips.com/topic/1568206-high-gpu-hot-spot-temps/
First, uninstall HWmonitor and install HWinfo64. HWmonitor is notorious inaccurate by today's standard for modern hardware, especially with AMD.
Second, a hotspot of +20C isn't uncommon, but if its +30C, then there might be poor contact to the heatsink. I would see if HWinfo64 shows the same characteristics before doing anything though.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
It's bad,  110C is  max acceptable temp  and your card  may  throttle or crash...
Maybe the card needs cleaning/repaste, or more airflow, try incresing fan speeds
Here's the info from HWInfo64
ill try to open the front temper glass and the front panel
Just now, So Corse said:
it doesn't make a difference from what i see when i open the side panel, for the GPU fans, they should be running at their max RPM
Usually when you have the core temp in acceptable ranges but a dramatically higher hot spot in excess of +30C, its because of poor contact or the thermal paste is defective in some way (could be poor application from the factory).
Its unlikely that the delta between the core and hot spot is that high due to a lack of airflow, but not impossible.
If you're comfortable doing it, repasting the graphics card would be a good idea. What's the history of that card? Was it something you got new or used and how long have you had it?
Sorry for the long response, i was trying to test 3D mark on it and still over 100C, i bought it used, but the seller claims that it was used for 6 months ish? for mining but in a "controlled environment". He bought it in 2022 i bought it in November 2023, i've had the Graphics card for 6 month more or less. if i want to replace the thermal paste, do i have to buy a special thermal paste/liquid metal or something like that or can i use the thermal paste for a Cpu?, i have the coolermaster pro v2, can i use that or nah?
thanks,
thanks,
though, i never changed a thermal paste on a GPU before, hopefully i don't destroy or break the Card if i decided to repaste it.
thanks,
