This is my C program for reading and displaying flight ticket details...
Pls compile and see the errors then help me fix it.... I am blankly saying this bcoz IDK how to explain my issue....
I promise this will be easier to fix than my last code..........
There are some pointer errors that's what I need to fix...
Thanks BTW :D
#include <stdio.h>
typedef struct
    int ptickno;
    char pname[100];
    char flightname[100];
    char fdate[100];
    char fltime[100];
    char class[100];
    char gate[100];
    char seat[100];
    char from[100];
    char to[100];
}passenger;
void input_output(passenger p1[100])
    int i=0;
    int n;
    int *ticket;
    ticket=&p1->ptickno;
    char *passname, *airplanename, *airdate, *airtime, *flclass, *airgate, *airseat, *flyfrom, *flyto;
    passname=p1->pname;
    airplanename=p1->flightname;
    airdate=p1->fdate;
    airtime=p1->fltime;
    flclass=p1->class;
    airgate=p1->gate;
    airseat=p1->seat;
    flyfrom=p1->from;
    flyto=p1->to;
    printf("ENTER THE NUMBER OF TICKETS YOU WANT TO ENTER : ");
    scanf("%d",&n);
    for(i=0;i<n;i++)
    printf("\n********************************************");
    printf("\nENTRY FOR PASSENGER %d :", i+1);
    printf("\n\nEnter ticket number     : ");
    scanf("%d",&p1[i](*ticket));
    printf("Enter name of passenger : ");
    scanf("%s",p1[i](passname));
    printf("Enter name of flight    : ");
    scanf("%s",p1[i](airplanename));
    printf("Enter date of flight    : ");
    scanf("%s",p1[i](airdate));
    printf("Enter time of flight    : ");
    scanf("%s",p1[i](airtime));
    printf("Enter class             : ");
    scanf("%s",p1[i](flclass));
    printf("Enter gate              : ");
    scanf("%s",p1[i](airgate));
    printf("Enter seat              : ");
    scanf("%s",p1[i](airseat));
    printf("Enter from              : ");
    scanf("%s",p1[i](flyfrom));
    printf("Enter to                : ");
    scanf("%s",p1[i](flyto));
    printf("********************************************\n");
    for(i=0;i<n;i++)
       printf("\nTICKET DETAILS OF PASSENGER %d",i+1);
       printf("\n\nTICKET NUMBER     : %d",p1[i](*ticket));
       printf("\nNAME OF PASSENGER : %s",p1[i](passname));
       printf("\nNAME OF FLIGHT    : %s",p1[i](airplanename));
       printf("\nDATE OF FLIGHT    : %s",p1[i](airdate));
       printf("\nTIME OF FLIGHT    : %s",p1[i](airtime));
       printf("\nCLASS             : %s",p1[i](flclass));
       printf("\nGATE              : %s",p1[i](airgate));
       printf("\nSEAT              : %s",p1[i](airseat));
       printf("\nFROM              : %s",p1[i](flyfrom));
       printf("\nTO                : %s",p1[i](flyto));
int main()
    passenger p[100],*pptr;
    pptr=&p[0];
    input_output(pptr);
    return 0;
https://linustechtips.com/topic/1290355-need-help-for-this-easily-fixable-c-program/
No, you are declaring a variable instead of declaring what kind of variable the function should expect. Should be:
void input_output(passenger *p1)
passname=p1->pname; airplanename=p1->flightname; airdate=p1->fdate; airtime=p1->fltime; flclass=p1->class; airgate=p1->gate; airseat=p1->seat; flyfrom=p1->from; flyto=p1->to;
Mmmno. Move these inside the loop and instead use:
p1[i]
Mmmno. Ticket points to a specific memory-address, not to an offset from p1. Also, you are trying to use the variable as if it was a function, which it isn't. Should be:
scanf("%d",ticket);
EDIT: Oh, for the love of god, the forum's formatting-stuff and its bugs are making my head hurt. For fuck's sakes.
Comments in the code
#include <stdio.h>
typedef struct
    int ptickno;
    char pname[100];
    char fdate[100];
    char fltime[100];
    char class[100];
    char gate[100];
    char seat[100];
    char from[100];
    char to[100];
}passenger;
void input_output(passenger p1[100]) //As was mentioned by others, this should be passenger *p1
{ //As a secondary note, you should be passing in the size of the array here, like you did in your previous topic you created
    int i=0;
    int n;
    //Purpose?  Why are you assigning all of the values to local variables...you can just write to them directly
    int *ticket;
    passname=p1->pname;
    airdate=p1->fdate;
    airtime=p1->fltime;
    flclass=p1->class;
    airgate=p1->gate;
    airseat=p1->seat;
    flyfrom=p1->from;
    flyto=p1->to;*/ //Really don't think this is needed
    scanf("%d",&n);
    for(i=0;i<n;i++) //If the person writes over 100 you are in trouble...always check against the size of the array
    scanf("%d",&p1[i](*ticket)); //Oh, this is...., just send in the pointer like you did above &(p1[i]->ptickno)
    scanf("%s",p1[i](passname)); //Same...just pass in the pointer p1[i]->pname
    scanf("%s",p1[i](airplanename)); //Repeat for all of yours
    for(i=0;i<n;i++) //Again check against the size of the array as well
       printf("\n\nTICKET NUMBER     : %d",p1[i](*ticket)); //Same as above...just access the things directly
int main()
    pptr=&p[0];//Purpose?  Not sure why
    input_output(pptr); //input_output(p); works just as well
    return 0;
3735928559 - Beware of the dead beef
11 hours ago, andreeacrst said:
Ah, this is why programming has always been just too much for me.
It all depends on where you start.  While admittedly it isn't for everyone, languages like c# are far more forgiving and easier to learn.  c is more difficult to learn, because you need to think about memory/pointers etc
Thanks BTW :D
#include <stdio.h>
typedef struct
    int ptickno;
    char pname[100];
    char fdate[100];
    char fltime[100];
    char class[100];
    char gate[100];
    char seat[100];
    char from[100];
    char to[100];
}passenger;
    int i=0;
    int n;
    int *ticket;
    passname=p1->pname;
    airdate=p1->fdate;
    airtime=p1->fltime;
    flclass=p1->class;
    airgate=p1->gate;
    airseat=p1->seat;
    flyfrom=p1->from;
    flyto=p1->to;
    scanf("%d",&n);
    for(i=0;i<n;i++)
    for(i=0;i<n;i++)
int main()
    pptr=&p[0];
    input_output(pptr);
    return 0;
Fixed?
#include <iostream>
#include <cstdio>
#include <queue>
using namespace std;
std::string getInput_str(void);
int getInput_int(void);
bool contRunning(void);
struct flightInfo{
    int ticketNumber;
    std::string name;
    std::string flightName;
    std::string flightDate;
    std::string flightTime;
    std::string flightClass;
    std::string gateID;
    std::string seatID;
    std::string origin;
    std::string destination;
int main() {
    queue<flightInfo> flightLog;
    bool running = true;
    while(running) {
        flightInfo tmp;
        printf("\nENTRY FOR PASSENGER %d :", flightLog.size() + 1);
        printf("\n\nEnter ticket number     : "); tmp.ticketNumber = getInput_int();
        printf("Enter name of passenger : ");     tmp.name = getInput_str();
        printf("Enter name of flight    : ");     tmp.flightName = getInput_str();
        printf("Enter date of flight    : ");     tmp.flightDate = getInput_str();
        printf("Enter time of flight    : ");     tmp.flightTime = getInput_str();
        printf("Enter class             : ");     tmp.flightClass = getInput_str();
        printf("Enter gate              : ");     tmp.gateID = getInput_str();
        printf("Enter seat              : ");     tmp.seatID = getInput_str();
        printf("Enter from              : ");     tmp.origin = getInput_str();
        printf("Enter to                : ");     tmp.destination = getInput_str();
        flightLog.push(tmp);
        printf(   "cont? [y/n]: "); running = contRunning();
    unsigned int _size = flightLog.size();
    while(!flightLog.empty()) {
        flightInfo tmp = flightLog.front();     flightLog.pop();
        printf("\nTICKET DETAILS OF PASSENGER %d", _size - flightLog.size());
        printf("\n\nTICKET NUMBER     : %d",    tmp.ticketNumber);
        printf("\nNAME OF PASSENGER : %s",      tmp.name.c_str());
        printf("\nNAME OF FLIGHT    : %s",      tmp.flightName.c_str());
        printf("\nDATE OF FLIGHT    : %s",      tmp.flightDate.c_str());
        printf("\nTIME OF FLIGHT    : %s",      tmp.flightTime.c_str());
        printf("\nCLASS             : %s",      tmp.flightClass.c_str());
        printf("\nGATE              : %s",      tmp.gateID.c_str());
        printf("\nSEAT              : %s",      tmp.seatID.c_str());
        printf("\nFROM              : %s",      tmp.origin.c_str());
        printf("\nTO                : %s",      tmp.destination.c_str());
    return 0;
std::string getInput_str(void) {
    char buffer[1024]{'\0'};
    scanf("%s",buffer);
    return std::string(buffer);
int getInput_int(void) {
    int buffer = 0;
    scanf("%d",&buffer);
    return buffer;
bool contRunning(void) {
    std::string _tmp = getInput_str();
    if(_tmp[0] == 'y') return 1;
    else return 0;
6 hours ago, wanderingfool2 said:
You used C++ instead of C.  If you use C++, might as well use std::cout and other C++ constructs.
I did use C++, I should have made that clear so the OP wasn't confused.
and using <cstdio> is perfectly valid, its still technically a part of C++.
You should post a code snip-it for comparison, adding relevant content will benefit everyone.
I never said it wasn't valid...I was just saying, if you are going to switch from C to C++ in a solution you might as well be using the C++ alternatives (which also can be safer)
e.g.
void unsafe() { //When input is 123456789
	char buff[9];
    scanf("%s", buff); //Buffer overflow's can exist
void cppsafe() { //c++ makes reading in safer
	std::string buff;
    std::cin >> buff;
My post was mostly about the fact that you said fixed but used C++, but didn't use anything that really benefited the solution (in my opinion).  If you are going to be using Strings to store, read in and print out data might as well use the C++ counterparts...otherwise a C solution would just make more sense in that you have less overhead of the string class and converting between the types.
Not a big deal, string::c_str just gives you a pointer to the underlying data. On the other hand, you have different fingers.. ohhh i mean, a reallocation will mes things up. This was bad, I know :D
ಠ_ಠ
Using converting between types might not have been the wisest choice of words from me.  For myself, it just makes things more cumbersome using std::string but then using the c methods of printing/reading.  It makes more sense to use stdout and stdin...or just writing the thing in c (just preference, but c code for this would look cleaner).  The copy constructor -might- be called when reading in (depends on the compiler and which C++ standard you are using).  Actually in this case, it is read into a buffer, then the buffer is sent into the std::string (which it would have to copy the buffer), and then potentially calling the copy constructor with the return.  It might not be a big deal, but it's still something to think about.
I still am by the same opinion, if one chooses to switch to C++ and use things like std::string, it makes sense to use the modern equivalents (otherwise for myself it's just adding additional overhead while not getting any benefits, especially the overflow situation)
*quick edit:  Actually I tried running a quick little test, where it's using c vs the cpp method...just scanning and putting it directly into a char* was about 32% faster than...which actually correlates to a similar question on stackoverflow https://stackoverflow.com/questions/21946447/how-much-performance-difference-when-using-string-vs-char-array
So I'm guessing the 32% is roughly accurate....not saying that it isn't good to use...just saying that there isn't a point in using std::string if one doesn't utilize the features afforded to it (because it doesn't necessarily keep the code cleaner)
e.g.
	char buff[9];
	std::string buff;
    std::cin >> buff;
I completely agree, 90% of the C++ alternatives are safer, and switching between types is a pain.
void see_safe() { //When input is 123456789
	char buff[9];
    scanf("%8s", buff); //Buffer overflow's can't exist
Thanks BTW :D
#include <stdio.h>
typedef struct
    int ptickno;
    char pname[100];
    char fdate[100];
    char fltime[100];
    char class[100];
    char gate[100];
    char seat[100];
    char from[100];
    char to[100];
}passenger;
    int i=0;
    int n;
    int *ticket;
    passname=p1->pname;
    airdate=p1->fdate;
    airtime=p1->fltime;
    flclass=p1->class;
    airgate=p1->gate;
    airseat=p1->seat;
    flyfrom=p1->from;
    flyto=p1->to;
    scanf("%d",&n);
    for(i=0;i<n;i++)
    for(i=0;i<n;i++)
int main()
    pptr=&p[0];
    input_output(pptr);
    return 0;
My pure C is a bit rusty.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdbool.h>
#define MAGIC_NUMBER 10
#define LINE(a) for(int i = 0; i < 30; i++) putchar(a); putchar('\n')
typedef struct {
    char x[200];
}prompt_x;
typedef struct {
    prompt_x p[MAGIC_NUMBER];
} passenger;
const char *_prompts[MAGIC_NUMBER] =
    "Enter ticket number     : ",
    "Enter name of passenger : ",
    "Enter name of flight    : ",
    "Enter date of flight    : ",
    "Enter time of flight    : ",
    "Enter class             : ",
    "Enter gate              : ",
    "Enter seat              : ",
    "Enter from              : ",
    "Enter to                : "
const char *_display[MAGIC_NUMBER] = {
    "TICKET NUMBER     : ",
    "NAME OF PASSENGER : ",
    "NAME OF FLIGHT    : ",
    "DATE OF FLIGHT    : ",
    "TIME OF FLIGHT    : ",
    "CLASS             : ",
    "GATE              : ",
    "SEAT              : ",
    "FROM              : ",
    "TO                : "
const char _other[] = "ENTRY FOR PASSENGER";
const char _other_b[] ="TICKET DETAILS OF PASSENGER";
const char _another_other[] = "cont? [y/n]: ";
int main() {
    int index = 0;
    char temp[2];
    passenger *me;
    me = (passenger*) malloc(0);
    while(running == true) {
        printf("%s [ %d ]\n", _other, index+1);
        me = realloc(me, (index+1) * sizeof(passenger));
        for(int i = 0; i < MAGIC_NUMBER; i++) {
            printf("%s", _prompts[i]);
            scanf("%199s", me[index].p[i].x);
        }LINE('*');
        index++;
        LINE('-');
        printf("%s", _another_other);
        scanf("%1s", temp);
        LINE('-');
        if((temp[0] == 'n') || (temp[0] == 'N'))
            running = false;
    for(int u = 0; u < index; u++) {
        printf("%s [ %d ]\n", _other_b, u+1);
            printf("%s%s\n", _display[i], me[u].p[i].x);
        }LINE('*');
    free(me);
    return 0;
