1080 ti buying help
Kanna
What modell should I look for when getting a 1080 ti used and should the founders be avoided?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
Most EVGA models were pretty much the best models you could get for the 1080ti such as the FTW3. I would say aim for those. Founders edition should definitely be avoided, it's hot, loud and is just worse overall.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
Blower cards, yeah, avoid
Unless you plan to watercool, which I doubt you will, knowing you
-sigh- feeling like I'm being too negative lately
I have the FTW3 model and it's great.
The Strix and Gaming X were both also excellent cards. IIRC, the Gaming X was the quietest of the 10 series generation as it used two larger slower moving fans compared to triple fan designs.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
I have the Asus Strix and it did me well for years. The blower versions have exactly the same problems as other blower cards, you'll likely hit thermal limit, and it'll make a noise while doing so.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Is there a list of cards that should be avoided?
Reminder⚠️
Yeah watercool is not my thing which you already might know
Reminder⚠️
Perhaps this list for GPUs should help.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
All depends on price. The founders cards are fine and such but really don't overpay for a older card. The 1080ti usually still goed for 400 or up which is the msrp of a 3060ti which is flat out better so might just wanna wait for those
Isn’t the 3060ti focused on 1440p?
Reminder⚠️
Yeah? So? The aim was higher frame rate 1440p. Why does that matter? Are you thinking it's going to perform worse at 1080p or 4k because of that? It's a high fps 1080p card and a 4k 60fps at good settings card.
I’m just thinking it might be a waste of money for just 1080p
Reminder⚠️
So is a overpriced 1080ti. That is still a 1440p high fps card too. What games do you want to play at what settings and fps?
Well go ahead and link be a 3800kr 3060ti in sweden then, I plan on playing cold war on high ish settings like max 60 fps for now and cyberpunk on some settings 60fps
Reminder⚠️
personally I'll get a 3060ti or 3070 FTW3 and I'll be playing at 1080p /60 fps *with shiny maxed out graphics* I couldn't care less if a old and used 1080ti could do the same the 30xx cards will be better in any way... ~
(already pre-ordered both, but especially the 3060ti seems like a good buy - whenever it's available lol)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
That can be done on far cheaper card for 1080 60. Also just wait for the 3060ti to go up for sale at normal price? They are available here and there in europe.
What card do you have now?
they're right, in a sernse that a better card will always be a better card, regardless of resolution (most of the time, unless two cards are very close in perf then sure, resolution may affect things, but this is not the case)
but again, depends on your local availability
buy the best card for your money, look at cards you can afford around your budget, then look at benchmarks
not... really
u need a 1080 minimum for that sweet overhyped but badly optimized game #5853764 60fps goodness
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Yeah the 3060 is better but then comes the availabillity
Reminder⚠️
2 minutes ago, Mark Kaine said:
not... really
A 1660 super is a lot cheaper than most used 1080ti's tho 😛 and yeah it's badly optimized game time again woop woop.
that's why i said, look for cards available to you, then check benchmarks
personally i got 3060ti just fine.
Actually might be getting the 3060ti anyways since I won’t get a new gpu until 2021 anyways
Reminder⚠️
Yeah I won’t get a new card until next year so futureproofing and spending little more shouldn’t hurt I will be able to max most games then
Reminder⚠️
3060ti for 1080p is pretty overkill, for today's games anyways
it's a mid-high 1440p card, for now
Yeah that is what I’m worried about (overkill)
Reminder⚠️
