my friend's phone got wet and wont start what to do?
3 hours ago, my username got flaged said:my friend phone got wet with salt water and it only vibrates water stickers are pink for the sim tray what to do it is not registering for windows
It's a small miracle the phone even powered up enough to vibrate after swimming in salt water. The problem with a phone getting dunked in salt water is that after saltwater dries, it leaves salt over everything. Salt will rust the metal components pretty quickly, especially the exposed metal like a USB plug. Rice wouldn't fix anything because there's still salt in the phone. Your best bet is to follow @huilun02 's advice. The purest alcohol you can find. Submerge the phone completely and let it soak for a few minutes. The alcohol will push out any water that might be trapped in the phone and push the salt out as well. The alcohol then dries completely clean with no residue left. Let it dry overnight and then try powering up or plugging it in. Other than that, you unfortunately have a dead phone.
