Ryzen hotter idle ish temps than 100% load
Solved by WereCat,
Thats normal.
Idle or one or two cores boost use up to 1.5V voltage so you see a very short temp spikes on only those cores.
In full load all cores are at around 1.3V so they all run cooler even though the entire CPU uses more power but over a much bigger surface area.
Featured Topics
Blazepoint5 ·
Posted in Programs, Apps and Websites3 -
4
1
1
10
Tamgam12 ·
Posted in New Builds and Planning14 -
4
Blizzforte ·
Posted in Programs, Apps and Websites7 -
Amzadd ·
Posted in CPUs, Motherboards, and Memory9
