Best 30 series card for 1080p 144hz?
Consul
A 3070 or a 3080? (Though I might go 1440p 144hz in the long run)
CPU: i7 8700k
gotta wait for benchmark to know for sure, but 3070 should be enough
3080 would probably help with future titles though at 1440p
-sigh- feeling like I'm being too negative lately
Yeah that's what I was thinking. From time to time I change my preference from a 3080 to 3070 just because of how high frames might bottleneck the CPU, but I guess it would help if I got a 3080 for the long run.
3070 for 1440p 144Hz.
For 1080p it's overkill, heck even the 5700XT and 2070S are considered overkill by some.
Edited by Mateyyy
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
2 minutes ago, Consul said:
a 3080 to 3090
i wouldnt touch the 3090 unless you're ballin'
2 minutes ago, Mateyyy said:
For 1080p it's overkill, heck even the ... 2070S are considered overkill.
REEE I WANT MORE FRAMES
using 2070S at 1080p is nice, constant high fps, little dips, silky smooth experience
plus you get to set high/ultra details
Yeah I mean.. I'm doing it haha
I meant to write 3070 not 3090 sorry haha
For 1080p it's overkill, heck even the 5700XT and 2070S are considered overkill.
It seems like I should wait for 3070's release & benchmarks.
Depends on the game.
I'm a flight sim fan, and I'm getting a 3080 for 1440p to try to hit 60fps in New York. If you want to use flight sim, I'd go for the 3080.
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
I will be playing AAA titles mostly, would like to crank up the settings as well.
Also, before anyone says anything, I know 1080p will be giving me bottlenecks but in the long run I feel like games will get more and more demanding, which to me seems like it would also be great to go for a 3080 for the long run (easy 3-4 years).
I have just bought a 1440p 144 Hz monitor in anticipation of the upcoming new GPU releases. I’m currently playing with a 5700XT on a 165 Hz 1080p. In my opinion it’s not overkill because I like to play games with ultra details and high FPS.
I’ll probably pick up a 3070 or equivalent AMD card and it should be good for 1440p 144Hz.
CPU i7 14700K | CPU Cooler Noctua NH-U12A | Motherboard MSI Pro Z690-A | GPU Zotac Airo RTX 4080 | RAM 32 GB GSkill Ripjaws V 4400
Mhz |
 Monitor Alienware AW2721D / Gigabyte M28U | PSU ASUS ROG Strix 850G
I have been dying to have that and that is why I REALLY want to buy a 3080.
22 minutes ago, geo3 said:
BS. You need to show benchmarks if you're claiming this.
Forgot to add "by some" after "are considered overkill", since this is kind of a subjective matter, but regardless:
CPU: i7 8700k
i can see a world where if you wanted native 1080p/144hz RT on you'd want a 3080 (dlss is really a blurry mess in some games barring dlss 3.0 improvements), 3070 will be enough for most cases
If we assume the 2080 ti =3070, it gets about 160fps in control at 1080p with RT on and DLSS off, and that game's a pretty fringe case, 3070 won' do 144hz on games like gtav with mods or RDR2 maxed, but in 90% of the games you'll be fine.
If you have a chance to go 1440p 144hz just get a 3080, the 8700k is also a small bottleneck at 144hz if it's not delidded, so do some research before dumping into a monitor and a gpu.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
So this is showing averages below 144Hz most games, so 1%'s are going to be well below, so pretty fuckin far from even adequate let alone overkill.
For a 3080, I would think that a 1440p 144Hz monitor would definitely give you a better experience. For 1080p 144Hz, the highest I'd go is a 3070 (or AMD equivalent).
Mhz |
I might go 1440p 144hz in the future, yeah. Delidding though? No, thank you, I would certainly fuck up something if I did that.
I see, thanks.
