Fan config for NZXT H710 with 280mm AIO
Solved by AncientPistol,
1 hour ago, TVwazhere said:I would keep the back as exhaust. Likely your CPU cooler fans will spin faster or at least push more air at the same RPM due to being larger than the 3-4 120mm at the top and rear.
A rear intake fan would just have it's air sucked up the exhaust top fan without ever have reached anything tho cool (except maybe VRM heatsinks)
Keeping the rear fan as exhaust, would you recommend 280mm (with rad) exhaust on top with 360 intake in front or 280 (with rad) intake in front with 360 exhaust on top?
