Nope, its not done yet, infact it'll never be done as my PSU has some awkardly short wires
RIG-Processor: Intel core i7 3770k @4.4GHz,Mobo: MSI Z77-G43,GPU:Gigabyte GTX 770, RAM:16 GB G-skill sniper f3,SSD: Corsair Force f3 240gb,HDD: Seagate baracuda 1TB,Cooler:CM Hyper 212 evo, Case: Sharkoon T28 Blue
Peripherals- Monitor: Samsung S24B300, Keyboard: Razer Blackwidow, Mouse: Razer Abyssus, Headphones: Razer Megalodon, Mousepad: Razer Goliathus Alpha, Webcam: Logitech C270,Pad:Logitech F710, Sp: Philips generic ones
#KILLEDMYWIFE #MAKEBOMBS
Tips:
- use cable ties
- get rid of useless wires like the hard drive activity light
- fully modular PSU's help
- braided cables (the fabric kind, not plastic) help as they are more flexible
- all black cables look more minimal even though they're still there
- try to minimise the use of Molex cables/connectors as they are massive. If you can, get piggy back Molex connectors so they're all in one place
- run your fans all to one spot, you can make a molex to fan splitter really easily with some wire and other bits
Laptop Lenovo Thinkpad X220 - CPU: i5 2420m - RAM: 8gb - SSD: Samsung 830 - IPS screen Peripherals Monitor: Dell U2713HM - KB: Ducky shine w/PBT (MX Blue) - Mouse: Corsair M60
Audio Beyerdynamic DT990pro headphones - Audioengine D1 DAC/AMP - Swan D1080-IV speakers
That looks absolutely beautiful. I suppose you are running off a server? Also, I noticed you didn't connect the audio header. Do you not get sound?
Thanks! my storage is network attached which helps clean it up a lot (my SSD in in the optical bays along with my 7v fan adapters). I use a USB DAC so I have no need for the mobo audio connector, removing it completely helped minimise the amount of cables.
Tips:
- use cable ties
How do you get so the 24Pin looks like it's bending a little? Because mine looks like shit.. And have you sleeved your cables?  But anyways, awesome build :D
Lyons, your cable management is immaculate... I'm just floored at how the back of that motherboard tray looks.
Here's my contribution. Trust me, you don't want to see the back side...
Looks great! I am really happy with everyone contributing to this thread!
The pictures look like junk but anyway here they are. Frankly the cable management is not great. Also my old gpu, doesn't matter haven't changed anything.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
Looks good! What fan hub are you using?
Built in one with the phantom 630/530.
Custom Motherboard Backplate with Routing Holes and Cable Combs.
http://www.overclock.net/t/1434204/sponsored-case-mod-elektron-electricity-a-nzxt-source-530-mod/140_20
[MAINFrame Customs Shop] | [Sleeving Guide Videos] | [Sleeving FAQ]
[Project Log]:[ Katharos ]: April MotM Winner | [Project Log]:[ Xýlo Kai Chalkó ]: Working | [Project Log]:[ Aspros ]: Done - 4th Place PDX Lan |
[Reason I Live]
Im not done with my cable sleeving yet, still have some cables still left to do but here is my cable management for now.
Bought new fans that go with the build, just wanted to post another pic to show what it looks like now.
Just my examples
post-61770-0-11034000-1393608189_thumb.j
http://www.iconicengineeringsolutions.com Computer Aided Design & Engineering Services.
Corsair C70 Case | i7 4820k @ 4.8Ghz | 32gb 1866mhz Ram | Asus x79 Delux Motherboard | 500gb Samsung SSD | 480gb OCZ SSD | 120gb ssd (drive cache) with 3tb HDD | Nvidia Quadro k4000 (Soon to be in SLIx2) | 8 x Corsair Air Series Fans | H100 Cooler
Tip: Make sure cable mess is not seen in photo and pretend you have good management  :P
c4oan9C.jpg?1
But in all seriousness heres mine, not your standard PC form factor though. I think its all about really planning cable runs, and taking your time and taming the mess.
Of3esQn.jpg?1
Rig: Lian Li PC-V353 i5 2500K, GA-Z68MA-D2H, EVGA GTX 650, CM Gemiin S524, Corsair TX650M, Crucial M4 128GB, Seagate 1TB Barracuda, Fiio E10
Not the best quality pictures but you get the idea :).  Tubing, fans, and hdd cage are temporary.
1555654_780983801931436_884770188_n.jpg?
1974522_780983945264755_915364350_n.jpg?
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
