One 6pin GPU two 6pin psu
Zediik
 Share
I want to buy AMD RX 570 that needs one 6pin connection but my psu Has 2 of them. Can i buy that GPU and leave the second 6pin in the case unplugged?
Yes.
yes you don't need to use all the PCIE power cables. How much are you paying for a 570?
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
143€
4 minutes ago, Zediik said:
143€
for that much get a 1650 or 1660
I'm sorry a 1650 ? Or do you mean the super Variant
Because the 1650 last time I checked Is a little better than a 1050ti and the 570 out performs both of them
Phone: Pixel 3a (Purple-ish).
Build Log:
Yeah
19 minutes ago, GDRRiley said:
Yeah
yea the  570 is a way better option
Build Log:
man GPU prices suck there.
yea but i guess there is nothing we can do about it lmao :D
Build Log:
 Share
