Best upgrade from gtx 1050ti with 450w cooler master psu?
Solved by boggy77,
6 minutes ago, Slottr said:A 570 is barely an upgrade. Don't bother if that's what you're going for.
A 570 is 30% better than a 1050ti. It still manages to get 60 fps on 1080p in most games and it fits his budget.
OP, if you sell you current card for like 80 and can put another 100 together, you can probably find a 1070 for 180 euros second hand. That should be better than a 570.
Featured Topics
MS-DOS ·
Posted in General Discussion0 -
skayqz ·
Posted in Graphics Cards5 -
youself ·
Posted in Linux, macOS and Everything Not-Windows0 -
3
cornexiors ·
Posted in Networking3 -
2
Shay04 ·
Posted in CPUs, Motherboards, and Memory2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
