Hi, i have wrote a piece of code however i cant remember how you get some data validation in. i want my numbers to stay within -10 and +10 and it should the display "invalid answer" and then ignore that user input however it just says in valid answer.
      bool bUserInput;
            sbyte sbNumber;
   if (sbNumber < -11 || sbNumber > 11)
                    //the error message
                    Console.WriteLine("Your are out of range please stay between -10 and +10");
                    bUserInput = false;
https://linustechtips.com/topic/1141401-numbers-in-range-c/
Errm.... Your question doesn't really make sense. But I believe the answer your looking for it the method int.TryParse(). Make sbNumber into an int not a sbyte.
This documentation should help you with it. If you have any more questions feel free to ask!
https://docs.microsoft.com/en-us/dotnet/api/system.int32.tryparse?view=netframework-4.8
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13183111
if(number > 11)
Means number 11 will be the maximum allowed number. Same for the -11 if-statement you're running.
You're probably looking for >= / <= or simply if(number > 10).
I can't remember if sbyte can be compared to an int too, so be sure to double check that part too.
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13183187
hi,
yeah so i am trying to make sure that it stays within range of those numbers like the flowchart seen bellow
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13183415
5 minutes ago, Daniboi said:
Hi,
This piece of code should work.
using System;
public class Program
	public static void Main()
		Console.WriteLine("Number: ");
		string number = Console.ReadLine();
		bool UserInput;
		int realNum;
		if (int.TryParse(number, out realNum))
			if (realNum <= -10 || realNum >= 10)
				//the error message
				UserInput = false;
Hope this makes sense.
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13183437
Just now, Ecchi said:
Hi,
using System;
        //hate to ask but the use of string? why?
		bool UserInput;
		int realNum;
				//the error message
				UserInput = false;
it sorta does
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13183443
26 minutes ago, Daniboi said:
it sorta does
  static void Main()
    Console.WriteLine("Please enter a number in the range [-10, 10]");
    int userNum;
    while (true)
      string userInput = Console.ReadLine();
      if (Int32.TryParse(userInput, out userNum))
        if (InputIsInRange(userNum, -10, 10))
          break;
        else
          Console.WriteLine("Invalid Number");
      else
        Console.WriteLine("Input is not a number. Please input a number between -10 and 10.");
    // If we're here, we're clear to do stuff with userNum.
  bool InputIsInRange(int num, int lowerInclusive, int upperInclusive) => ((num >= lowerInclusive) && (num <= upperInclusive));
This appears to be homework. I would not recommend copying my use of expression bodied members (the "=>" syntax on the InputIsRange declaration) because it may raise a red flag to your teacher.
ENCRYPTION IS NOT A CRIME
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13183652
  static void Main()
    int userNum;
    while (true)
          break;
        else
      else
And they usually have software to check if it's plaguerised, plus it's not really learning if copy/paste without understanding it :P
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13188480
10 hours ago, Erik Sieghart said:
There's some fundamental understanding issues with your code. I would read @straight_stewie's code to reference the individual parts that are different from yours. These misunderstandings are:
  • The use of sbyte instead of int.
  • Not obtaining the input from the user.
  • Believing that the input can be stored as an integer.
so i was told sbyte and this is only a very small bit of my code
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13189405
Don't associate me without that code
Image result for pepehands gif
https://linustechtips.com/topic/1141401-numbers-in-range-c/#findComment-13191892
