Linustechtips Dark Web Notification
Solved by colonel_mortis,
The number of breached accounts listed there exactly matches the number of accounts that we know were breached in September 2015 (although from what I have seen of the dataset, it actually predates that slightly), so I'm pretty confident that this is not a new breach.
If you may have been affected, you should have been emailed at the time (in 2015), but if you're concerned then please feel free to send me a PM to check.
To the best of my ability to tell, this data seems to have been circulating for a while in some very deep parts of the internet.
