Best Ryzen 3600 Air Cooler
Stilg7
I'm wondering what would be the best air cooler for minor to moderate overclocking?  I have these three in mind so far:
-Scythe Mungen 5 Re.B ($47)
-Noctua U12S ($56)
-Noctua D15S ($71)
I'm not 100% sold on one yet and I'm open to anything. TIA
PBO already does this, and you'll basically get the performance you're after with stock cooling. For a stronger OC, go for the D15S, might as well go all out.
Primary PC:
Have you tried using the stock cooler first?
The coolers mentioned are great if you're aiming for low noise but isn't necessary if you don't think the stock cooler is too noisy.
As an owner of both a 3600 and a 3700x...I can tell you without any doubt that the stock cooler on the 3600 is garbage.
Techspot put a good AIO water cooler on both a 3600 and a 3600x and they both PBO'ed to the same mhz. So arguably, the low end cooler on the 3600 holds it back to satisfy the price premium for the 3600x. It is kind of shady IMO
I put the stock cooler from my 3700x on my 3600 and the 3600 is performing much better.
For my 3700x, I bought the Arctic Freezer 34 duo. It is the best value to performance available. $40 on Amazon and it even came with MX-4 thermal paste
https://www.amazon.com/ARCTIC-Freezer-eSports-DUO-Configuration/dp/B07MC8CRVZ/ref=sr_1_1?keywords=arctic%2B34%2Bduo&qid=1566419908&s=gateway&sr=8-1&th=1
Ryzen 3700x w/ Arctic Cooling 34 eSports DUO || MSI B450 Gaming Pro Carbon AC || GSkill DDR4 3200 CL14 @ 3600 16-16-16 || EVGA 2070 XC Gaming || WD Black 1T NVME, WD Black 2T 7200 rpm || EVGA SuperNova 750 G1+
Most cpus are just dies that couldn't be used for higher end models. They're artificially held back to create product lines. It's not shady but is just what happens when most of the cost is in research and development as opposed to raw materials.
For a 3600, i recommend the u12s. I used it in my build and am quite happy with the cooling it offers. At 4.2 ghz all core OC and testing using intelburn software, it holds at 68deg c through 10 passes on high
On 8/19/2019 at 4:17 PM, hello_there_123 said:
The stock cooler.
Stock coolers are garbage on Ryzen 3000. There is no copper core/vapor chamber anymore. Load puts mine in the low 60c range with a hyper 212 Evo.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
3600(non-X) uses the stealth anyway.yet some reported it throttles a bit under heavy load
The new stealth is not as good as the old stealth. Again, garbage inadequate cooler like what Intel ships with their CPUs.
Black Knight-
Daughter's Rig;
The copper was only removed from the Wraith Spire and the newer version seems to perform at least as well.
https://youtu.be/Lfrdy3wG_g0?t=305
https://youtu.be/zHhRPTEJ9GY?t=233
Can you link any sources for that?
All I've found comparing the two is this: https://www.reddit.com/r/Amd/comments/acxul7/psa_new_wraith_stealth_fan_update_roughly_the/plai
It explains the changes that allow for shroud removal and better case compatibility but not cooling results.
Black Knight-
Daughter's Rig;
2 hours ago, asand1 said:
The results were with an oc'ed 3600x instead of a 3600 and don't compare the newer and older Stealth coolers.
It's not unlikely the issues were due to bad oc settings as opposed to insufficient cooling since 71c isn't very high for load temps.
