Best budget air cooling case with optical drive slot
Neftex
Im looking for a new case, i really like the performance of Silverstone RL06 but it lacks the optical drive slot and the filter at the bottom is annoying to put back in. So id like to ask you for some recommendations
so what would i like:
budget below $110 (including fans if i need to buy extra)
optical drive slot
all intakes with filters (easy to take out and put back in without opening the case, i guess either slide out or magnetic)
very good cooling performance with acceptable noise
should fit big cpu cooler
some room for cable management behind mobo
dont care about rgb
MSI GX660 + i7 920XM @ 2.8GHz + GTX 970M + Samsung SSD 830 256GB
9 minutes ago, Neftex said:
big cpu cooler
Phone book
All the room you need! ?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Maybe the Focus G? It's the only one with an optical drive that I can think of off the top of my head
I'd recommend taking a look at the cooler master website. They have a TON of high airflow cases with optical drive slots. Not sure what you're looking for style wise, but personally I've never really liked the looks of any cooler master cases.
~Air Cooling Advocate~
Focus G is the one that comes to mind
Builds:
the focus g bottom filter is really annoying to put back, seems even worse than on the rl06.
the 88R has closed front so good cooling performance is highly unlikely
the cooler master nr600 has the same bottom filter as rl06 but at least it comes with magnetic filter for the top which i could probably slap on the bottom instead. it needs another fan to perform well, which i wouldnt mind buying. overall i like this suggestion the most, but in my country the nr600 (extra fan not included) is already more expensive than the rl06 which comes with 4 fans (wtf)
at this point im thinking of just getting the rl06 and an external optical drive
Then why not consider Meshify C?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
Have to agree! Such a good airflow in that case
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
meshify c is more expensive and performs worse than the rl06. needs extra fans to catch up which adds more cost. it does have better bottom filter access, thats true
On 5/31/2019 at 9:51 AM, Avius said:
Cooler Master NR600 W/ ODD
This!
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
