Best Air-Cooler
I was wondering what would be the biggest and best air-cooler that would fit inside the Coolermaster H500P Mesh, don't care about sound but please list the price next to it, but as long as it will fit and i can put it in the case and crank the fan(s) rpm to max. Only limitations are the case and must be compatable with LGA1151 and/or AM4.
Edited by Zvoid
Missing Details
CPU: Amd Ryzen 3400g
COOLER: Be Quite Dark Rock Pro 4
MOBO: Aorus x570 elite
RAM: 2x8 Corsair Vengence 3200 MHz
SSD: Samsung 970 Evo Plus 500GB
GPU: Powercolour Red Devil RX570 4GB
PSU: Corsair RM750x 80+ Gold
CASE: Coolermaster H500p Mesh
NH-D15 is the best you can get
Builds:
D15
Could i replace the fans with these ones, if so would it make any improvement ???
https://www.amazon.co.uk/gp/product/B00KFCRF1A/ref=ox_sc_act_title_32?smid=A38F5RZ72I2JQ&psc=1
NH-D15 and DRP4
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Just now, PacketMan said:
If you want black fans, check out the Be quiet Dark Rock Pro 3 or 4, similar to the Noctua in price and performance
Its not so much the colour, but the very high rpm as i would be using these at max
i mean, those 1u deltas
but seriously speaking, if any degree counts, yes, but otherwise no
Deepcool Assassin III
Personal Desktop":
Luna, the temporary Desktop:
i doubt those would make anything better, the fans on the D15 are good stuff already
Builds:
NH-D14/NH-D15 use clips that attach to 120mm fan mounts, so you'd want 120mm fans or something like the NF-P14r or NF-A15 which they come with already.
The NH-D14 you used to be able to use Megahalems fan clips for 38mm thick fans, maybe that would work on a NH-D15? I'm sure someone's put some big obnoxious fans on one by now.
they come with 140mm fans.
if it was 120mm you would want to replace them with sterrox fans like on the Nh-U12A
The NH-D14 comes with one NF-P14r and one NF-P12 or whatever their previous model names were before they were rebranded into the Redux line. The NH-D15 comes with two NF-A15's. Not a single one of these fans will mount like a standard 140mm fan.
2 minutes ago, Slayer3032 said:
The NH-D14 comes with one NF-P14r and a NF-P12 or whatever their previous model names were before they were rebranded into the Redux line. The NH-D15 comes with two NF-A15's. Not a single one of these fans will mount like a standard 140mm fan.
just had a doublecheck. no they wont mount as standard 140mm fans. but if you are going to replace them. you should probably use 140mm fans
Quote
Round 140mm frame with 150mm width
The NF-A15 is tailor-made for use on today's high-end CPU coolers: While its 150mm width matches those of most high-end heatsinks, its 140mm height doesn't make it extend on top and thus ensures best case compatibility. The NF-A15's standard 120mm mounting holes (105mm spacing) also make it an ideal performance upgrade for 120mm case or CPU fans.
they do have regular 120mm mounting holes tho.
using the nh-d14 you could perhaps replace 1 of the fans with Sterrox and add a second sterrox.
Noctua NH-D15
beQuiet! Dark Rock Pro 4
Cryorig R1 Ultimate
Zalman CNPS9900MAX
These are the best of the best in dual tower air coolers (afaik). All 4 should perform within a few degrees of each other.
I have the Noctua and the Zalman and can speak to their performance. The Zalman in particular is nice because it is quite cheap, at $25 USD on Amazon.
Edit: PSA: The Zalman does not ship with an AM4 bracket. You can send an RMA request to Zalman about the AM4 bracket and they will send you one. However, as of right now, Zalman is temporarily out of stock of AM4 brackets for these coolers.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
What cpu are you cooling? Is noise not an issue?
Moved to Air Cooling.
Not one specific cpu and was stated in the first post that noise was not a concern, just what was the OVERALL best air cooler.
The socket limits what coolers can be used.
fixed
The NH-D15 with the 3000rpm NF-A14's or some other very high rpm fans might be about as good as it gets for air cooling. You can see the same NF-F12's compared on some other large heatsinks here: https://www.hwcooling.net/en/how-sensitive-is-ninja-5-to-airflow-changes/3/
You can contact Noctua for 140mm fan mounts like those here in RelaxedTech's test of the same configuration: http://www.relaxedtech.com/reviews/noctua/nf-a14-industrialppc/7
BGears b-blaster fans are really good at cooling AIOs and air coolers. (They have a 140mm fan that outputs 308cfm and has an mmH20 of 31.08 at 12V but sucks up 2.76 Amps) (DON'T PLUG IT INTO THE MOTHERBOARD HEADERS!!!!)
140mm that I just mentioned - https://www.newegg.com/Product/Product.aspx?Item=N82E16835132046
120mm one that outputs 218cfm https://www.newegg.com/Product/Product.aspx?Item=9SIAG7X7HF7800
https://www.bgears.com/b-blaster/ -specs of each fan
Do you have a cpu in mind?
