i7-9700K Stuck on 3.6GHz under load - Help
34 minutes ago, Plutosaurus said:don't know that specific board, but probably. do it in the bios. make sure your power doesn't fail. should be fine. please report back if it works.
then once you confirmed your problem is fixed
OC that badboy
Well well well, would you look at that.
BIOS is updated to newest one available from ASUS, and suddenly it works as it should.
Here is some screenshots from after i updated to this new BIOS.
Cinebench r15 improvement: https://gyazo.com/4b73b5db45743fd38e5570852a791d37
HWiNFO core speed: https://gyazo.com/dd2324f7a71ca054acfac432ff8f70ba
HWiNFO temp: https://gyazo.com/fb63d7ce3becedf42f66c8f651604134
So apparently updating BIOS to the newest version, fixes the issue for the i7-9700K not Turbo Boosting as it should.
I find it abit weird a bios version would fix that, but apparently does.
Thanks alot for the help guys. Much appreciated.
