Recommendation for 980ti psu
M0SIE
I need a fully modular or semi psu above 600w any suggestion?need for 980ti founders
whats the rest of your specs?
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
4 minutes ago, LukeSavenije said:
600w? what are the other specs?
System
  • CPU
    Ryzen 7 1700
  • Motherboard
    ASUS B450M-A
  • RAM
    T-Force Night Hawk(2X8GB)3200Mhz
  • GPU
    Gtx 980ti founders edition
  • Case
    TecWare Nexus M
  • Storage
    Silicon Power Ace SATA III 256GB SSD
  • Cooling
    ID-Cooling FrostFlow 120+
7 minutes ago, M0SIE said:
System
  • CPU
    Ryzen 7 1700
  • Motherboard
    ASUS B450M-A
  • RAM
  • GPU
  • Case
    TecWare Nexus M
  • Storage
  • Cooling
you don't need a 600w
8086k
aorus pro z390
evga 3070 ultra
Where are you from and how much $ can you spend on this PSU?
Personal Desktop":
Luna, the temporary Desktop:
4 minutes ago, Princess Cadence said:
Where are you from
Looks like it's Singapore based off his location
120 usd
Just now, M0SIE said:
Currently i have a a evga b3 550w psu
You could use it being honest, it's not the best solution by far but it should buy you a couple of months in order to get something better, thinking on the future.
TXM, RMx, G2, Prime... etc.... follow that tier list linked above.
Personal Desktop":
yeah... that isn't going to cut it. if you look up reviews, you'll also see that it's been golden sampled to them
it's not wattage, it's quality, it lacks a couple protections for example
Bitfenix Whisper M 550w; Corsair TX550M; Seasonic Focus Plus Gold; BQ Straight Power 11 550W
Life is really challenging. I don't always suceed: )
yeah... no
yeah
Corsair TX550M
a little loud for some
yeah
1 minute ago, LukeSavenije said:
yeah... no
Sorry, SS FPG is probably the most popular of those around my country, and I see it recommended roughly 6-7 times per day. That is why I tend to "go with the crowd". I prefer Whisper M though. I've only listed these, as they have roughly the same price for the same wattage, and all of them is around 100-110USD.
yeah... it isn't the best, it has problems with the OCP which was fixed, but made it not sensetive enough, it doesn't kick in on 125%, which it should
17 minutes ago, LukeSavenije said:
yeah... no
yeah
yeah
Hows the rosewill hive 650w modular
I have a 980ti Overclocked like a mother and on a 280mm cooler with a 1700x Overclocked like a mother to 4ghz on a 360mm cooler and 3 HDD and 14 noctua fans 6 120mm and the rest 140mm since all the rads are push pull in the core x5 by thermaltake and my PSU monitors power draw and under full CPU and gpu synthetic load I pull 600-700 watts so I'd say a 650watt if you don't push the oc and a 750 if you push hard with the fans, rgb and oc
Edit: I got a EVGA 750w supernova g2 for around $100 on Newegg and has been great for 2 years so far and has an eco fan mode for silent operation, to prevent extra dust and save power by not spinning the fan till needed saving the fan bearing and power.
a nope from me...
Not great but should be OK for what you have.
No need to replace it right now, IMO.
But how about a Silverstone Strider Platinum??
yes, maybe, no, yes
"Hell is full of good meanings, but Heaven is full of good works"
Are you having problems that you think are power supply related?  Because that PSU is more than enough.
Working fine gaming but when running fire strike msi afterburner stats says power lim
That's a software limit. The GPU has a power limit, and will reduce its boost if it meets it.
Dang anyway to remove it?
You can increase the power target, get a custom overclocking BIOS with the power limit removed, or add a resistor in a specific place on the GPU.
