PC 60 FPS vs Ps4 Pro
ILoveBatman
Is there any difference between ps4 pro's fps (perhaps 30) and pc's fps (30) at 4k? Some of my friends are trying to make me think that 30 fps on a console is not as 30 fps on a pc.
I mean, besides graphics quality and resolution, 30 fps is 30 fps
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
Well to start with. 4K on console is quite often upscaled from a different Rez than 4K. This doesnt apply to all titles offcourse. It just means some titles arent rendered in 4K. Same can be done on PC if you so please.
Second consoles run at lower settings to achieve the performance it does.
Assuming both devices run 30 fps max and min, its identical.
So its a bit of a tricky thing with the ps4.
Quoting from a reddit thread "the PS4 Pro is actually taking 1440p (2,560 x 1,440) and upscaling it to 4K (3840 × 2160)."
So its more like 1440p scaled up using the PS4 Pros admitedly pretty good upscaler. Compare this to say the Xbox One X which usually does render at native 4k, or the PC you asked about in your OP which also theoretically is running native 4k the PS4 is going to be a tiny bit more blurry.
Plus on the PC you get the added benefit of tweaking settings to your preference. Take me for example, at 4k aiming for lower settings I disable all AA, motion blur, turn down special effects and particles, model geometry, etc so that I can turn things like lighting, shadows, and textures up higher.
30 fps on a console is actually worse, the input lag (and the slow display + image effects) of the TV make it far worse compared to monitors.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
That (as admitted in your statement) had nothing to do with the system. Yiu can use consoles and PCs on any type of display you want.
Two of my friends have Playstations (one of them has a Pro) and they experience noticeable FPS drops in many games. Consoles aren't as optimized as Sony would have you think.
Ryzen 1600x @4GHz
Asus GTX 1070 8GB @1900MHz
16 GB HyperX DDR4 @3000MHz
Asus Prime X370 Pro
Samsung 860 EVO 500GB
Noctua NH-U14S
Seasonic M12II 620W
+ four different mechanical drives.
No. But there is a massive difference in what you are actually looking at on screen. Console decreases the quality in certain things to achieve 30 fps while a PC can achieve much higher fps without decreasing anything in the quality of certain things.
The real question is, why do you ask this question? PC is hopefully what you'd rather be gaming on.
Coming from someone who actually dicks around with that kind of thing, it entirely depends on the game.
If a game has a good vertical sync implementation on both consoles and PC, then it should roughly feel the same to play. I'll take Driver: San Francisco as an example: that on the Xbox 360 has a really nice v-sync implementation and it very rarely buckles below 60fps and the same goes for the PC version, least on my PC. Both roughly feel the same to play, even through a capture card on Component video. That being said I'd rather play the Xbox 360 version but that's a different discussion entirely.
Now, if a game doesn't have a good v-sync implementation (Valve games feel really terrible to play with v-sync on, all of them) then it will likely feel worse on console, especially if that game is capped at 30fps.
That's total nonsense.
Because:
Exactly that is how it is.
The System you play it is independant from the display, that described above is an issue with the Display, not the console.
Depends what you are really talking about, the game and so on.
In general: fps = fps, regardless where it is done.
However you have different settings on PC and Console usually the console is somewhere in the medium - high range while you have ULTRA and more than that on PC as well.
Inputlag and other stuff shouldn't be too much different either, if using the same screen for both.
"Hell is full of good meanings, but Heaven is full of good works"
If we want to be technical, 30 FPS may not feel like 30 FPS due to how the frames were spaced out. Console developers will try to aim for consistent frame times, but a PC game may not be designed as such since consistency can be hit or miss depending on the environment.
Assuming both use the same monitor resolution:
Moving from 30 FPS Console to 30 FPS PC = Big NO!
Moving from 30 FPS Console to 60 FPS PC = So-so, it's just a side move.
Moving from 30 FPS Console to >120 FPS PC = Absolutely worth it.
For also moving to higher monitor resolution, it's a different story..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Well on pc you should aim for vrr-range fps. I think it usually starts on 35-40Hz. It will be a lot better as vsync adds 1-2 frame delay because of the buffer, and with low 30 fps that is 33ms or 66ms.
