CL17-3600Mhz or CL14-3200Mhz
Only reason to buy the 3200MHz CL14 kit is because you're using Ryzen and you're too lazy to set your own timings (as in, even the primary timings which has 5 to 7 values). Ryzen simply can't make 3600MHz profiles work without manual interference on most boards (and those that do will have horrible secondary and tertiary timings that make you lose performance and waste money).
Otherwise you should get the 3600 CL17 kit, it's a higher bin than 3200 CL14 so OC potential is higher. The performance difference with their XMP profiles on Intel is negligible (3600 CL17 has higher bandwidth, 3200 CL14 has lower latency), but Ryzen's design on linking memory frequency with uncore (infinity fabric) frequency makes 3600 CL17 perform better than 3200 CL14 at their rated settings respectively.
Oh, and the best value memory ratings is still 3000MHz CL16 because they are so cheap.
