Water Cooling Asus GTX1660ti OC O6G 6gb
Solved by Xkillerpn,
71C is fine, if you really need less noise just get a Accelero 2 from artic, the accelero 4 will be overkill on that card
Featured Topics
Fireord36 ·
1
azyrroth ·
Posted in Home Theater Equipment0 -
Andrew john ·
Posted in New Builds and Planning24 -
2
