Ceramic/Stone tile under PC tower viability for cooling
Solved by suchamoneypit,
2 minutes ago, somenoob said:Thanks for the no sense replies! I live in Australia where the ambient temperature gets above 30-40 degrees. Wanted to see if a tile would absorb the heat in the room to prevent it from effecting the tower. I think I might have not made that clear.
The thermal mass of a tile is not anywhere near enough to make a difference on an entire room, nor does it have any way of conducting heat effectively from the entire room. Even it it could, it would be heat saturated extremely quickly and serve no purpose. Even if you cooled the tile to below freezing and put it under your PC, it would have practically zero effect on the computer.
