thinking of water cooling
this might be a bit ambitious as this will be my first pc build but should i go for water cooling and what parts would you recommend
should i use hardline or flexible tubing  as this will be my first ever pc and my budget is only £1200 gbp for the whole build
if anyone could recommend water cooling kits or tell me reasons why i shouldn't water-cool it would be greatly appreciated thanks :3
Arctic frost
my first build
cpu: intel i5 8600k
cpu cooler: ARCTIC - Freezer 33 eSports ONE
motherboard: Asus ROG strix z370-E
ram: Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-2133
ssd: Kingston - A400 240GB 2.5" Solid State Drive
hdd: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
gpu: Asus - GeForce GTX 1060 6GB Dual Series
case: NZXT - S340 Elite (White)
psu: EVGA - B3 550W 80+ Bronze
thanks to @seoz for helping make the list :P and its based of her custom rig
You should probably look at AIO's instead.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
maybe i did think of getting an aio but what i wanted was a clear tubing with red liquid and i cant find an aio cooler that has that
Arctic frost
my first build
cpu: intel i5 8600k
£1200 budget wouldnt fit well for a custom loop, you would have to sacrifice performance to get a good loop.
Sugest sticking with a high end aircooler for now. Add in a loop later.
Dont use AIO's. They dont perform good enough to justify the cost over a top end air cooler. They are only really usfull in small form factor builds where large heatsinks cant fit.
A good "semi-premium" Intel i7 bassed build will cost you more than £1200.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
As this is your first ever PC build an AIO in this case would make more sense for you, building a custom loop requires a lot of time and dedication as well as the regular maintenance to keep the loop in good shape and performing correctly.
زندگی از چراغ
The high-end units like the Corsair H115i do beat out some of the high-end air coolers.
زندگی از چراغ
as it stands the pc im thinking of costs £900-£1000 so that would leave me with £200 for a cpu block and a water cooling kit but i could save up what would you say i should spend for a water cooled pc?
Arctic frost
my first build
cpu: intel i5 8600k
not really sure what this price point comes from, this is $1500 US. That's definitely premium, not "semi premium." Step it up from there and core i9 is in reach.
Primary PC:
Trash beauty:
Xeon X5560RX 570 4GB (defective) -Fattydove Racing 240GB - WD Blue 320GBHP Z400 - 6x2GB DDR3 1066 - EVGA 450W3
i might go with an aio but none of them suit the style i would like
Arctic frost
my first build
cpu: intel i5 8600k
 Well lets say you built a semi premium high end machine like this
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (£308.00 @ Amazon UK)
Motherboard: MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard  (£99.99 @ Ebuyer)
Memory: Corsair - Vengeance LED 16GB (2 x 8GB) DDR4-3200 Memory  (£177.00 @ Amazon UK)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  (£87.59 @ Aria PC)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB FTW3 GAMING iCX Video Card  (£718.99 @ Amazon UK)
Case: Thermaltake - Core X31 ATX Mid Tower Case  (£91.49 @ Scan.co.uk)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£94.96 @ Amazon UK)
Total: £1578.02
Generated by PCPartPicker 2018-07-22 14:55 BST+0100
You then add on a GPU block, CPU block, a Large 360 rad, a pump, a res, a bunch of fittings, and tubing.
of the top of my head i'd say another £300-400
  Reveal hidden contents
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler  (£79.99 @ CCL Computers)
Total: £1658.01
Generated by PCPartPicker 2018-07-22 14:53 BST+0100
what if i went with this and upgraded the gpu later with a gpu block for a 1080ti
https://uk.pcpartpicker.com/list/B2KQGG
and then got a cpu block and water cooling kit i could then upgrade the gpu later?
Arctic frost
my first build
cpu: intel i5 8600k
Never build a PC just for the looks, you've got to think about what is practical for you as a user. I suggest you buy an AIO first, keep that for about 2 years then once you feel it is the right time to build a custom loop go and build it.
زندگی از چراغ
i mainly go for looks my original budget was £800 but for looks and water cooling i moved it up to £1200 as im going to be gaming mainly so i thogh of buying this https://uk.pcpartpicker.com/list/B2KQGG getting a water cooling kit and upgrade the gpu to a 1080ti and water block later on but if i cant fit it in the budget an aio will have to do for now i just dont like the look of the black sleeved tubes
Arctic frost
my first build
cpu: intel i5 8600k
You 'could' go that route but ur wasting money in the long run. Also even EK's entry kits are £200+, without a GPU block.
A full custom loop with asthetics in mind isnt somthing u can/should do on a lower end budget. Its an enthusiast thing, its expensive.
Personaly i would recommend a £2000 budget. Thats for a top of the line PC + waterloop parts.
To be brutally honest you'd be wasting your money water cooling an i5, I know it's unlocked but a high-end air cooler would be enough for that.
زندگی از چراغ
Get a heatsink or AIO.
Unless you want to spend half of your budget on watercooling and end up with a crappy $700 PC.
let me put it this way.
My rig u see in my sig.
It started with a Nh-D14 aircooler. No loop. I built the system 1st using all my budget. Then later i added in CPU loop. Then added the GPU later down the line when the Classified block was released..
thanks for the advice i will go with an aio for now then and save up for a water cooling loop later on
Arctic frost
my first build
cpu: intel i5 8600k
Still sugest you get a top end aircooler. AIO's are a waste money when you can fit a large tower cooler. Your choice though :)
From the impression I got you were wanting an i7 8700K which is top of the line and a CPU that should warrant the use of water cooling, after you reveled you were wanting an i5 8600K a high-end air cooler is all you need. Don't bother with water cooling.
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
AIO's are worth the money if you have hardware that can warrant the use of it, in this case the OP is wanting an i5 8600K which doesn't warrant the use of water cooling.
زندگی از چراغ
i will probably do this
https://uk.pcpartpicker.com/list/37YCD2
and upgrade later in the future to a gtx 11 series when they release and water cool then
Arctic frost
my first build
cpu: intel i5 8600k
Which CPU are you going for?
You link a list with an 8700K then you link one with an 8600K.
زندگی از چراغ
8700k as ive decided to get a better cpu and gpu and get water cooling later on when the gtx 11 series releases
Arctic frost
my first build
cpu: intel i5 8600k
For some reason I still get the impression that you are still undecided in what you want, take some time to think it over and come back with a proper plan.
زندگی از چراغ
