Cooling CPU
4 minutes ago, JacTech17 said:ill probably upgrade my system to am4 in the future. so will there be a significant temp difference between the heatsink and the water cooling setup
If you need more processing power you should upgrade.
Just like in case of Intel's NetBurst/Pentium 4, making lots of heat per work is only thing Bulldozer is actually good at.
Any overclocking will only make it fast even bigger space heater. (like FX9590)
Though cooling per noise could be improved.
While Bulldozer stock coolers are vastly superior in cooling power to Intel's stock HSFs (because of lot less efficient CPUs) those are still rather small and light compared to any third party coolers.
And unlike in water pipe coolers you can get really good cooling performance for very reasonable price and still without blocking DIMM slots or PCI-e slot.
Scythe Mugen 5 (Rev B for AM4 compatible mounting kit) doesn't cost much.
Especially if wanting good longer term reliability you have to pay really lot more from having water pipes in place of heat pipes.
