550w Corsair psu enough for Gtx 1080
I have a Corsair 550W Power supply right now and a I5 8600k at 5.0 GHz stock voltage, I want to get a Gtx 1080 or the next 1180 (or whatever they call it) will 550W be enough, also running rgb lights, ram keyboard and mouse if that makes a difference.
Should be enough. What model is it? I recommend the Corsair CX550M.
hi.
No problem.
Gtx 1080
Also no problem
We don't really know. But we DO "know" (everything seems to back this up) there'll likely be a die shrink. I would expect similar power consumption, maybe even a reduction of power consumption.
Practically none.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
Yes am using the cx550m, thanks
1 minute ago, chckovsky said:
No problem.
Also no problem
Practically none.
Ok thanks for the info won’t have tot worry about power now?
Not sure I'd use a CXm for an i5k + 1080 build, wattage is fine but it's a budget PSU for a higher end build...
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
The CX550M isn't terrible, but surely if you can afford a 1080 you could bump it up to a TXM or some other PSU without a sleeve fan? This TX650M has way more wattage than you need but is on sale and is a better unit.
https://pcpartpicker.com/product/PVzZxr/corsair-txm-gold-650w-80-gold-certified-semi-modular-atx-power-supply-cp-9020132-na
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
He already has it, so no reason to buy another if he doesn't absolutely need too.
One observation I've made is that the 1080 Ti makes the main transformer squeal (as it does in pretty much every double forward based PSU out there) under heavy loads.
Other than that, it should be fine.
