Case Choosing HELP
5 members have voted
  1. 1. Which one of these Cases would you choose?
    • NZXT S340 White Elite
    • Cooler Master H500p Mesh
    • BeQuiet! Dark Base 700
    • Fractal Design - Meshify C
    • Cougar - MX330
    • Corsair Carbide Clear 600C
So I've been looking at a few cases, but I don't know what kind of case would fit my build? If you guys could help me out that would be awesome! Some I had in mind myself were: Coolermaster H500p Mesh, NZXT h700i, Corsair 400C.
My Budget is around $175 for the case.
These are my components:
CPU: i7-8700k
CPU COOLER: Corsair150i pro rgb or Corsair h100 v.2 (haven't decided yet)
GPU: Asus Nvidia Geforce GTX 1080
PSU: Coolermaster V750 80+ Gold
MOBO: Asus Prime z370-a
STORAGE: Samsung 960 evo 500gb m.2 + samsung 850 evo 500gb
MEMORY: G.Skill trident z rgb 3200MHz 16GB
https://linustechtips.com/topic/910851-case-choosing-help/
CPU: i7-8700k
If you have the money for the H500p, get it. <removed>
Edited by SansVarnic
Intel Core i7 4790K 4.8GHz | MSI Z97 Gaming 5 | 32GB 2133MHz CL7 DDR3 | nVidia GeForce GTX 1070 with Custom BIOS | Samsung 850 Evo 500GB | 3TB Seagate FireCuda SSHD | 2TB Seagate FireCuda SSHD | Corsair CX750M  | Custom 240mm all-in-one liquid cooler | Broadcom NetXTREME 5709c Dual Gigabit NIC | Cougar MX330 mid-tower chassis | Windows Server 2008 R2 Datacenter
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187104
Is that the "founders edition" Asus card, or their STRIX tripple fan card?
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187105
CPU: i7-8700k
Is there anything you are looking for in a case? I personally like Fractal Design cases because I like the minimalistic look and plenty of dust filters (to help lower maintenance).  I'm using the Fractal Design Meshify C. (It's small and has tempered glass too).
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187149
<removed>
Anyways the reason I ask this is because if it's the strix Edition, I cannot recommend the Meshify C Which is kinda the Go-To case, in which case the Enthoo Pro M TG is the best alternative under $100. Above $100, The Define R6 is probably the best case for the money. I believe the H700i is technically out of budget, as most places have it for around $190 unless I'm missing some sort of sale going on, and the H500P Mesh has great airflow but leaves much to be desired in the cable management.
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187151
In all fairness cases are pretty much all the same functional speaking they hold your hardware and can house fans so it's much more about what you like whether it's aesthetics or build experience than functionality. Choose your AIO cooler first before choosing the case so you know which you one you need.
Edit: Also don't let the strongly opinionated individuals decide for you.
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187152
2 minutes ago, jtmoseley said:
LMAO And the coolermaster h500 has good airflow? You are joking right?
I don't care about airflow, the look is all that really matters. And I am not one for the RGB mess that the h500p is.
To be fair, OP reference the H500P Mesh that has the updated front panel and top panels which are significantly better
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187156
Still, it is dumb to fault NZXT for having bad airflow when their goal wasn't ever airflow. Its not like they advertised high airflow everywhere then came out with a tempered glass panel in front of the fans
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187163
I'm not going to lie, that made me laugh in a good way.
As it should, it was in jest.
Personally? I like the Cougar MX 330. It's my current case.
SLI GTX 1070s. A mistake.
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187165
1 minute ago, Joelss said:
It's their Strix triple fan card ^^
Ah, then you would not be able use the Meshify C since you'd have to front mount the H150i pro, as that card is otherwise too long. :(
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187187
Heya, so I've come up with some cases, that look good to me, but I want to hear what you would choose!
Once you've chosen one of the answers leave an explanation why you would choose that one!
If you have any other case suggestions, leave them down below.
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187307
-= Thread Cleaned =-
Lets keep to the topic at hand.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187465
57 minutes ago, DarkStang said:
You have a very wide range of sizes and styles there. Comparing the compact Meshify C against the large H500P doesn't seem right.
I'm more asking what people prefer than comparing them.
I got some 180$ on here, but also some 70$.
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187621
Definitely keep your PC specs on here, as it matters wen choosing which case will actually fit all the stuff you need (that 360 AIO and Asus Strix card for example).
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11187647
None, get the Fractral Design R6 in white with TG, looks amazing!
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11189648
Ryzen Ram Guide
https://linustechtips.com/topic/910851-case-choosing-help/#findComment-11189650
