BEST GRAPHIC CARD FOR RYZEN 5 1400
ARC_
I BOUGHT A PC WITH 4 GB RAM AND A RYZEN 5 1400 WHAT GRAPHIC CARD TO BUY I ALSO RENDER VIDEO AT 1080P 60 FPS
Second hand or brand new?
Personal Desktop":
Luna, the temporary Desktop:
First things first, tap on caps lock. Second, you don't exactly need a graphics card to render a video. (Correct me if I am wrong)
980s are pretty cheap used in the UK right now... What are you looking to spend?
Your right, its all in the CPU. I would recommend a 1050ti if you are not gaming.
MONY IS NOT A PROBLEM !
NO I DO GAMING
Then go for a used 980 or 1060 6GB if you can find it cheap. I'm assuming you are also going to be gaming at 1080p too
Best graphics card without economic constraints would be a Titan V.
Now, what's your full build and your budget?
4GB of RAM is way too low.
CPU: Ryzen 7 5800X Cooler: Corsair H100i Platinum SE Mobo: Asus B550-A GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB (DDR4) SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
YES I DO KNOW AM USING ASUS B350 MOTHERBOARD BUT TITAN 5 LOOKS TOO FAR OVERKILL FOR 1080P
I think (if ''mony'' isn't a issue) he will buy titan v and have only 4Gb ram -offtopic-
What is ''TITAN 5'' ? Can you send me a link ?
Edit: Oh Titan V like roman numbers... get it now...
TITAN V
Please don't use cap locks.
Well, first of all, get at least 8GB of RAM, or if you really want to throw away money get 16GB given the current prices.
As for a GPU go for a 1050Ti, or if you want to throw away even more money go with 1060 6GB.
Unraid Server
CAN I GO WITH GTX 1060 3GB ONE?
get at least 8gb of RAM, 16gb is good but expensive.
for 1080p, the best GPU to get if money is not an issue is gtx1070. future proofing and not overkill
OKAY I CAN BUY A 1070 BUT WILL IT BE A BOTTLENECK FOR RYZEN 5 1400
No, it shouldn't be a bottleneck as the Ryzen 5 should be perfectly capable. Unless you wanna go on the really safe side go with a 1050ti or just go for a 1060 3GB. Simple as.
depends on the game you play. If you mainly play CSGO and League of legend the yes, if you play AAA, its good. As games getting harder and harder to run, gtx1070 will keep you satisfied longer, while 1060 is good for now, it will be harder for it to keep up in the next 2-3 years.
THANK YOU I WILL GO THAN 1060 3GB
55 minutes ago, SpaceGhostC2C said:
If money is not a problem, I suggest getting yourself a keyboard with a working Caps Lock key.
        My PC:
  • Asus Prime-B350 Plus. Ryzen 7 1700Ballistix Sport 16GB DDR4 2400. EVGA GTX 1070 SC
  • 256GB SSD/ 3TB HDD. Corsair CX650M. CoolerMaster Masterliquid Lite 120. Fractal Design Meshify C
  • Reidea KM06. Redragon M601. LG 34UM67-P. Arion Legacy AR504LR-BKMass Drop AKG M220 Pro
I mean, I'm not accusing the OP of anything, but the thread title and every post in caps and that username thats written in a unique language that only me and him understand that literally translates to trol... Erm ....trollop.
Linus is my fetish.
@xDD find your caplock key and remove your caps. it isn't necessary to reply in all caps as internet etiquette takes this as shouting. shouting is not needed.
Ryzen CPUs don't have integrated graphics cards. So OP would need a GPU if that's what you're getting at...
@xDD If you're not gaming, a GT 1030 could do the trick or a GT 740. If you're on a tight budget and wanna game, look into maybe a RX 460 or RX 560 or GTX 1050 or 1050 ti
NO I DO GAMING
Alright, then depending on what you wanna spend... 980, 980ti, 1070, 1070ti, 1080 are all good options.
For the R5 1400, I'd say actually an 8GB RX 480/580 or GTX 1060 6GB or GTX 1070/1070ti would be fine options.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
