How many times can a DVD drive be opened and closed?
Solved by Boomwebsearch,
I discovered the issue earlier today in the morning. The issue was that the physical cables connecting the drive to the power supply had worn out. After replacing the cable/s the drive is now functioning as normal although I am not entirely sure why the connectors had worn out. I think that it probably got worn out due to age although there is really no way to know for sure. Thanks to everyone who posted and contributed to solving my problem. I hope that this drive will continue work in the future.
