Hot temps after GPU repaste
Solved by Biohazard777,
3 minutes ago, Gianluca95 said:i tried to replace the thermal pads and paste (i used a noctua nh-1)
i can't open any serious 3D application. I tried some games and it goes immediatly to 88-90 degree while the fans go to the max.
The pads you used are probably too thick and not squishy enough.
(thus making the gap between your heatsink and the GPU die bigger)
Try with original pads (if they are still usable), find the right thickness pads, or use thermal putty instead of pads.
