Ryzen 7950X: using motherboard video outputs and integrated graphics to add more monitors
Solved by TylerD321,
Just now, Blasty Blosty said:As in the motherboard outputs will not be available if a dedicated GPU was in use
That’s not true. Usually integrated graphics are disabled when gpu plugged in but it’s also usually possible to re enable it in bios.
Yes you can do this @will0hlep
Featured Topics
maartendc ·
2
Fluuwu ·
Posted in Cases and Mods0 -
2
8
MZSAN ·
Posted in Home Theater Equipment0 -
loadironmania ·
Posted in Storage Devices6 -
Sevan ·
Posted in Troubleshooting7 -
Cael Thunderwing ·
Posted in Graphics Cards0 -
6
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
