Why isn't 4k 4times slower than 1080p?
Light-Yagami
I've wondered for quite some time why games's fps don't scale according to resolution. In games I've watched gameplay of and benchmarks, most of the time the number is around 2.5-3x performance decrease. So if 1080p was sth like 140fps, 4k would be around 50-60 mark.
Why is that?
This is because goign form 1080 to 4k the gpu starts working more instead of the processor.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
Not everything being computed is just the exact pixels so there's some overhead and then there's processing stuff for the UHD/1080p.
Anti aliasing for example, 4k benchmarks usually dont run as high AA settings by default
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
computing scaling is never linear
It's the same reason when looking at multi-core or multi-CPU computing. 4 identical cores will never perform 4 times better than a single core. 2 "identical" CPUs will not perform twice as good as a single CPU.
The way a scene is rendered isn't linear either. Some elements (can be a single pixel or a cluster of pixels) don't require the same amount of computing as others.
I think (and don't quote me on this) there is also some approximation going on (to relieve some computing stress)
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Because some graphical settings, geometry, etc... have the same-ish performance impact regardless of resolution.
Same fps percentage drop regardless of resolution? is that what you mean?
Thanks for info.. I've noticed yeah.. How much multicore CPUs perform in terms of performance per core scaling heavily depends on program optimisation and on how cores work together.. it that makes any sense..
Diminishing return? Also game perdormance scaling isn't 4:1, even though the resolution is.
Try using the PSU Tier List!
How to reset the bios/clear the cmos
My current rig:
CPU: Ryzen 7 3700x
Ram: 1x16gb DDR4, 2x8gb DDR4
Storage: 1tb nvme ssd
GPU: gtx 3080
Monitor: 23.8" Dell S2417DG 144hz g-sync 1440p + 27" Acer S271HL 60 Hz 1080p
Keyboard: ducky one I | I SF
Mouse: gpro wireless | glorious model o2 wireless
Sound : beyerdynamic 1990 pro | Monoprice liquid spark (amp) + topping d10 (dac)
I'm not sure if you can select which cores remain active on a multi-core CPU, but if you can you'd probably find that each of them perform differently, at least in theory.
While the differences might be insignificant, they should be there.
Not everything a cpu does is related to putting the actual pixels on the  screen.
A lot of computing work is done by the gpu, most of which doesn't get harder at 4k than it is at 1080p.
GPGPU physics, for example, don't need more ressources at higher resolutions.
You might also have bottlenecks that shift from some components to others. For example, a cpu bottleneck at 1080p could easily turn into a gpu bottleneck at 4k.
Anti-aliasing is something else entirely. Unless you are talking about SSAA, most anti aliasing techniques find ways to reduce intensity by not actually rendering the entire scene at a higher resolution, but only smoothing out edges, for example.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
At least in my tests, it basically is:
I get around 25-30% performance at 4K in most games.
2560×1440 is 1.77 times as many pixels as 1080p so you would expect 1/1.77 or 56% as many frames per second, and that's pretty close to what I get too.
Perhaps other reviewers use different graphics settings when they test at 4K. Also bear in mind that high-end graphics cards may encounter CPU bottlenecks at lower resolutions which would prevent 1080p from being 4 times higher than 4K results.
Some of it depends on the work being done. All of the geometry stuff like positioning and manipulating primitives are done independent of resolution. Everything after the rasterization step is what's ultimately affected by resolution.
It also depends on how fast the CPU can pump out draw commands to the GPU. At lower resolutions, the GPU is able to accept more of them in a given time frame. At 4K if the GPU can only pump out 60 FPS tops, that means the CPU is sending out 60 draw commands in a second. At 1080p, the CPU would need to send 240 draw commands in a second, which it may not be able to do after processing the logic
Why is that?
I dont know for sure but  if i had to guess then maybe cause game physics and stuff uses the same amount of resources regardless of resolution
The thing is 1080p is more reliant on CPU, whereas 4k was more reliant on graphics performance. assuming 60fps each.
Also graphics scaling is never linear as far as I know.
CPU: Intel Core i7-7700K | Motherboard: ASUS ROG STRIX Z270H | Graphics Card: ASUS ROG STRIX GTX 1080 Ti OCEdition | RAM: 16GB G.Skill Ripjaws V 3000MHz |Storage: 1 x Samsung 830 EVO Series 250GB | 1 x Samsung 960 PRO Series 512GB | 1 x Western Digital Blue 1TB | 1 x Western Digital Blue 4TB | PSU: Corsair RM750x 750W 80+ Gold Power Supply | Case: Cooler Master MasterCase 5 Pro |
Cooling: Corsair H100i v2 // 4x Corsair ML140 RED Fans // 2x Corsair ML120 RED Fans
Monitor: ASUS ROG Swift PG279Q 1440p 165Hz IPS G-Sync | Keyboard: Corsair K70 LUX Red LED, Cherry MX Brown Switches | Mouse: Corsair Glaive RGB | Speakers: Logitech Z623 THX Certified Speakers
While I agree with the sentiment, "never" is too strong a term for it. There are lots of tasks that are trivially parallel and DO scale linearly with more resource.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
fair point. I was probably thinking in terms of resulta generated by a benchmark
