fan controllers Your thoughts on PC fan speed controllers
I have in my case 8xCorsair AF120mm Quiet edition fans. When I installed them and turned on the PC it sounded like an airplane taking off. I tried to control the fans through motherboard but no luck. I bought an NZXT GRID+ V2 and plugged them all in the back and now my motherboard looks cleaner without all the wires from the fans. Still control the fans through CAM Software which is developed by NZXT so compatible with the GRID.
Reasons:
1. Cable clutter in front of the motherboard
2. Number of fans possible to connect to the motherboard
3. Some of them offer you a much better and easier GUI for fan control (to the ones applicable like in my case CAM Software)
P.S You can check my fans in the link from my signature.
