Does this PSU have 4+8 pin power connectors
Go to solution Solved by Enderman,
1 minute ago, gamingneeded said:
Ok as an example this AX1200i can power 4+8 motherboards since one 4+4 will go to 8 pin plug on motherboard and the second 4+4 will go to the 4 pin plug. sorry for being so annoying but this is my first build so i am bit confused
Yup.
If you look at the specs it says "EPS connector : 2"
http://www.corsair.com/en-eu/ax1200i-digital-atx-power-supply-1200-watt-80-plus-platinum-certified-fully-modular-psu
That means it has two sets of 4+4.
Can someone tell me if this PSU is compatible with This motherboard
Asus - ROG STRIX X99 GAMING ATX LGA2011-3 Motherboard
Thermaltake - Toughpower Grand RGB 850W 80+ Gold Certified Fully-Modular ATX Power Supply
i am worried about 4+8 pin power connectors on motherboard.
https://pcpartpicker.com/user/GamingNeeded/saved/DjKwP6
Thanks in advance
The motherboard CPU/EPS power connector is called 4+4 not 4+8.
It says on your PSU "4+4 CPU" directly on it.
Well you don't need a 4+8 pin to use it and it wont make a difference if you don't.
Do you already have that build? If you don't there are a few changes id make. like:
- Get a r7 1800x or 7700x instead. No reason to get a 6850k, if you really want x99 get a 6800k, the extra lanes won't help
-Get a single 1080 ti before sli, just not worth the hassle.
-Id get a single bigger ssd, nvme isn't really worth it and a 1tb ssd is nice.
The ROG STRIX X99 board has the highest RMA rate of any X99 board. The platform is at end of support, and not a good choice if this is a new build with x299 and x399 right around the corner.
The PSU only has a single 4+4, so you wont be able to connect both a 4 and 8 pin connections on the motherboard. You shouldn't need to connect both though, just the single 8pin.
Linus him self said those are some BS boards, plus to expensive for me. so what MB would you recommend, and what are the extra 4 pins for
I use the X99 Taichi myself (previously had the X99 Strix briefly), although if you are willing to wait a little bit, see what happens with Intel's X299 and AMD's X399 platforms. AMD is putting pressure on Intel again (finally), which is making the CPU market more competitive.
The extra 4 pins allows power draw to the VRM to be balanced over more wires, reducing the risk of the wires melting. In the ATX power specification, each wire is rated to deliver a certain amount of power, although this rating is significantly lower than what the wires can practically do safely in the real world. There is quite a bit of safety margin in this.
The only reason the system would need to draw that amount of power to the VRM would be in extreme overclocking which would not be recommended for 24/7 operation.
Thanks in advance
That PSU will work for that system, yes. That said, others suggested Ryzen and if you don't need to use this PC for a living (due to flaky Ryzen memory issues) then I'd agree with them.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
The motherboard i named needs 8 pin (4+4) and another 4 pin.
I would recommend getting a different motherboard or different PSU, because it may or may not work without the other 4 pin.
What PSU, i cant find a PSU that has 4+4 and another single 4 pin connection, where does the extra 4 pin connector come from, PCIe???
No, there are PSUs that come with two sets of 8 pin (aka 4+4 pin) EPS/CPU connectors.
Since you can split them in half you can use just 4 of one of the 8.
Yup.
4 minutes ago, gamingneeded said:
Thank you a lot now i understand everything.
You're welcome :)
