ledstrip 12V ledstrip doesn't work with powerbank
The power bank has USB ports which support fast charge. Basically the power bank sends 5v through the USB cable on the other end of the usb cable there has to be a chip which "talks" to the power bank and tells it that it can handle higher voltage, it can charge batteries at higher voltage, so the power bank "understands" that it can raise the voltage to 9v or 12v for faster charging and only then the power bank will switch from 5v to 9v or 12v.
By default, without some chip telling the power bank to raise the voltage, the power bank will default to 5v.
Your power strip has no such chip on it, so the power bank will always output 5v.
You can buy dc-dc converters that work in step-up mode (also called boost converters) or in SEPIC mode (buck/step-down or boost/step-up) which can convert the 5v to 12v , plenty of them on eBay and other stores.
