EVGA 600 B1 80+ BRONZE 600W will be enough for a GTX1080?
RRGT19
Hi,
A store locally is selling the EVGA 600 B1 80+ BRONZE 600W (100-B1-0600-KR) at US$ 61.00, it will be enought for this?:
  • i7-7700
  • Asus H270F
  • 16GB 2400MHz
  • EVGA GTX1080 FE
  • Seagate Barracuda Pro 4TB
  • Samsung 960 EVO 250GB
They are also selling the 700W model (100-B1-0600-KR) at US$ 81.00.
Just now, Electronics Wizardy said:
Its enough power(the 600w) 1080s don't use that much power.
even if I add 2 or 3 hard drives, or maybe in the future a GTX1080Ti, will be enough?.
It'd be enough to power it but you'd ideally want a higher quality power supply unit to power a i7 7700 and a GTX 1080.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
system in sig,i'm only pulling about 300-400w(400w absolute max i've seen so far) while gaming.
you'll be fine but i'd go for a higher quality psu
pic from the pcmr subreddit/about 2 years old
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
If you can afford a 1080, you can afford a good quality power supply.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
Why not link the LTT PSU Tier
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
It would be enough power but you really would want a better PSU with those high-quality parts. If you can get a 1080 and an i7 you should be able to get a modular, higher efficiency, quieter, etc. There are some really good PSUs out there that aren't much more expensive. Seasonic has some good ones.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
like EVGA G3 650W?
4 minutes ago, RodoGodo19 said:
like EVGA G3 650W?
That's a good one.
Also, it seems like you're always building a new PC, lol. Do you actually ever complete your builds? Or are these for friends?
Yeah, I have like 2, I'm a maniac... this build will be a cheap one for a girl....
the others are for friends
In what way are a GTX 1080 and 7700 "cheap"....?
Anyways, as has been noted: you can afford top of the line hardware thus you can afford top of the line insurance against killing it, I.E. that EVGA G3.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
its based on this anyways
While it could be biased here and there, the advise of getting the EVGA G2/3 550w or 650w is rock solid, it would be the best PSU to pair with a 7700k + gtx1080
Personal Desktop":
Luna, the temporary Desktop:
agree with that,just not the 600 B1
I have a budget build with a 450w EVGA bronze and I got it to boot and run fine with a 7950. I think the 7950 takes more juice to run than a 1080. With that said a 600w should be fine but I would say go for 650w to 700w to be on the safe side.
The quality matters more than the wattage.
Full Specs
Helios EVO (Main):
Delta - Laptop
I once had a high end OCZ 700w power supply years ago. It sat in storage for several years. I put it in my system in my signature and watched and waited wondering how many days, weeks and months it would last before dying. It lasted a few months over a year before it died taking no components with it. The over under on that model was 6 months as they were known to be a defective model.
With that said, I am an EVGA fan. I think their power supplies are of very good quality and they have a 5 year warranty. I have been building computers since 2003 and if you saw the junk I have seen in the past. Computer components have come a very long way in quality over the last several years.
