GPU is not using 100% [no bottleneck]
LoweredHippo
Hi everyone,
My GPU doesn't use 100% while gaming. It recently started doing this and I don't know why. It isn't a bottleneck since my cpu is not always on 100%. It is with some games tough.
The GPU uses around 20% to 70% percent while I'm gaming. It is not overheating or anything.
I started FurMark and ran a stress test (furmark_000001 attached). The core clock was used 90% - 100%. But the memory clock was only used for about 6% to 10%. I don't know if this is normal or not.
The low gpu usage happens with every game. I don't know what it can be so hopefully you guys can help me out.
System specs are attached. If you need any more information please let know and I will provide it.
Thanks!!
ps: I did already ask this on Reddit and xXTonyManXx helped me a lot already. Maybe you can take a look so you know more about what we already tried.
ps2: HERE is a recording of me playing BF1. Maybe it gives you a better idea of whats happening and what may be the cause.
DxDiag.txt
a GPU shouldn't be on full load when playing most games.
what games are you playing? Unless they are extremely demanding then that's normal.
Evga GTX 1080 SC ACX | Ryzen 5600X | MSI Tomahawk B550 | 16GB Vengeance 3600MHz | EVGA 650P2 | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
Are you experiencing frame drops in your games ? cause if didn't result in FPS loss then it's normal since GPUs run at 90~95% most of the time in most games.
Edited by LawrenceBarnes2013
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
Unless you're having FPS issues this is completely normal, BF1 and Insurgency are both CPU intensive.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
Memory clock usage at low usage is normal.
About games ... well not all games can fully utilise your GPU.
For example Guild Wars 2 will only use 40% of my GPU at best. It's just not that demanding game.
But if you want to see your GPU at 100% load while gaming, you should try Overwatch at epic graphics settings. That will put it at 100% load for sure.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Do not use FurMark ever, it kills video cards, if you want to benchmark use Unigine Heaven, set it all to the max settings on your native resolution, if it reaches 99% on there then the GPU is fully working, the video card not always get maxed on certain games as it can render everything without the requirement of going full clock speeds.
Personal Desktop":
Luna, the temporary Desktop:
1 minute ago, LoweredHippo said:
@treeroy Really? I thought it was supposed to be  on full load. It always was on full load before.
@LawrenceBarnes2013 Sometimes I do. But my overall framerate is way lower than it was.
So this drop in GPU Usage did effect your frame rate ?
@Simon771 My gpu never uses the full 100% anymore. With BF1 I'm playing with aroud 40-50 fps while it was 70+ before.
What CPU are you using and what's your CPU load and temperature?
WD My Cloud 4TB
Then FurMark already damaged your gpu, =/
do the Heaven test like I said and log its status using HWMonitor or MSi Afterburner or something so we see how it is performing,
Personal Desktop":
@LawrenceBarnes2013 Yes it did
I'm guessing driver update.
What do you mean by "damage" the GPU? I've never heard of software damaging something.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
FurMark throws unrealistic huge stress on the GPU forcing its power and heat to the limit what can damage GPUs if used for even not that long period of time, 99% usage on GPU in gaming or more realistic benchmarks such as Heaven is the cores waiting for further instructions while in FurMark it is because its doing math equations constantly everywhere, there are many reports of cards that died after some extended period of benchmarking with FurMark, in fact even Linus have stated in many of his videos that you should avoid this application.
Personal Desktop":
Some benchmarks can stress components too hard and cause damage to them, Prime95 is known for doing it too if ran for too long.
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
1 minute ago, Princess Cadence said:
FurMark throws unrealistic huge stress on the GPU forcing its power and heat to the limit what can damage GPUs if used for even not that long period of time, 99% usage on GPU in gaming or more realistic benchmarks such as Heaven is the cores waiting for further instructions while in FurMark it is because its doing math equations constantly everywhere, there are many reports of card that died after some extended period of benchmarking with FurMark, in fact even Linus have stated in many of his videos that you should avoid this application.
Oh, OK. I guess I just haven't run across this issue. I won't use FurMark now.
Main System: Phobos
-bad internet double post, mod delete if seen-
Personal Desktop":
RAM can also be a bottleneck he should check that, too (maybe he has only 8GB and Chrome open in the background)
Just as an external input since it's not likely to occure on your card ...
 the R9 Nano  has a similar behavior on stock (and it's more or less intended) because of it's extrem power limit, you may have to turn the max. Power Limit up a bit to get a performance increase.
On the R9 Nano the card may throttle also with ramped Power Limit and good GPU temps. The reason behind this is that the card also thermal throttles when the VRM temp reach 100°C, which can happen in a bad airflow case. (use HWMonitor to read VRM temps)
So maybe just try and raise the Power limit a bit and check your VRM temps while in game.
@Princess Cadence So I ran Heaven benchmark while monitoring with HWMonitor. The gpu is under full load when the benchmark is running. 80%-100% when it's playing and sometimes drops quickly to maybe 30%-40% and then gets back up.
@Narnash My temps are fine. I'll try to raise the power a little bit. I'll let you know it works.
@TrigrH It also happens with games that only use 70% of my cpu. And I never had the problem before with BF1. Even when the cpu was running at 100%
This could be a case of the core clocks being too high, is the GPU overclocked?
Personal Desktop":
Gamins is all about speed, your CPU even when not being maxed out can still be too slow to process drawcalls fast enough to properly feed your GPU.
What CPU do you have?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
RAM is not a bottleneck. If the program needs more RAM than is available it should just crash.
@Princess Cadence I use the OC mode in Gigabyte Xtreme Gaming Engine. When I press OC Mode the only thing that changes in the program itself is the GPU Clock. It adds +26MHz.
