Gaming with low electricity bill
_chuck1z
So, my pc consumes around 600 kwh each months.
Specs:
6700k
1080 FE
Noctua NH-D14
Asus MX279H
Only plays Dota 2 :)
more than 100 hours usage each months
How to reduce my bills?
Specs:
6700k
1080 FE
Noctua NH-D14
Asus MX279H
now what do ya want to do/ask?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Um... What is the topic of discussion cos there were no questions.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
600 KWH doesn't tell us anything. How many watts does your PC use? How many hours do you use your PC a month?
-KuJoe
What's the point of this? This isnt very low-power hardware, its very wasteful for the game you play.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
I like the latter half of the second sentence.
It's such a waste indeed. Beyond sad imo.
Specs:
6700k
1080 FE
Noctua NH-D14
Asus MX279H
Why not just get a i5 laptop ( U models ) with GPU to play ONLY DOTA on it.
Will cost you less electiricty Bill then your PC Setup.
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
how to reduce my bills
Buy cheaper hardware and a better efficiency power supply. A 460 would be plenty for Dota 2, also a very efficient PSU may help slightly.
PSU Tier List
My specs
PC:
Peripherals
Already got a laptop, asus x550ze a10-7400p + r5 m230. It sucks so bad at dota
game less
don't buy such high end stuff
and how does it even work that you need that much electricity with that hardware?
let's do some maths:
I estimate based on my system and your tdp: you need around 95W CPU+180W GPU +50W rest of the hardware+20W monitor: ~350W
If you would consume 600kWh, you're PC would need to run 600000 Wh/350W = 1700 h a month which equals 55h a day under full load.... do you see where's the problem?
I guess the number you told us  is wrong. If you're whole household needs 600kWh a month, then try to find the leak.But it isn't even possible with that system to be the single factor
- Ryzen Build -
2x Dell UP2516D
Just now, rhyseyness said:
460 probably consumes as much/more power than the 1080 tbh
A RX 460? A low power card that doesnt require any external power connectors consumes as much or more than a high end card? Just look at the recommended PSU wattage to see the difference.
PSU Tier List
My specs
PC:
Peripherals
Just now, 19_blackie_73 said:
game less
My whole household consumes around 1000+ kwh a month
Thought you meant a GTX460.
RX 460 would definitely be a better choice, haha
lol, you can prove this isnt the case just by googling the power consumption.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
But your PC cannot even consume that much power if you saw the maths.... how did you get the number?
- Ryzen Build -
2x Dell UP2516D
So you think your PC is responisble 60% of your household electricity bill?
That would mean your fridge, washing machine, kettle, boiler, lights etc. all combined are consuming less power than your PC alone.
Something isn't right in your calculation.
i second your calculation is wrong and i second getting a better laptop
ψ ︿_____︿_ψ_
let me do the math again
so if you need 65kWh a month for your pc which equals gaming 6h a day, I coud live with that
- Ryzen Build -
2x Dell UP2516D
Just now, Bouzoo said:
So you bought what is one of the most expensive PCs that costs a fortune, but have issues with paying for electricity. That makes perfect sense.
yep
