So i recently got a Asus Dual 1070 8gb and i realised it's not performing up to what i expected so i launched hwmonitor to see my core clock at 1582mhz which happens to be the base clock of this card when i already oc'd it in afterburner. Unigine Valley also reads my core clock as 2000mhz when it still says 1582 mhz on hwMonitor. Help plz
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/
Try GPU-z. Valley has issues reading clocks on Pascal based GPUs. Also make sure your settings are applied in afterburner.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8823205
Use MSI afterburner while running a stress test to make sure the temps are fine and see what the clock speed is.
HWmonitor might not be accurate.
If you see afterburner also shows 1500MHz then please post a screenshot of afterburner.
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8823208
Actually another common issue is that the pascal cards (and I think all Nvidia cards on recent drivers) tend to get "stucked" on lower maximum power states so even if the game demands more performance it won't go to the full boost clock, sometimes stucked at 1500ish, sometimes stucked at 1200ish, sometimes my card was even stucked at the bare minimum of 169mhz or so.
This behavior should change after restarting the driver so just reboot your machine and try again. If it keeps happening sorry to say there isn't a solution as of yet to this, best thing I've found to avoid a soft reset everytime is to use  GPU-Z to attempt to export the GPU bios this will immediately reset the driver (You don't even need to save the BIOS you can cancel out of it) and it should boost back up to your max.
Current Rig
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8823226
Valley has issues with quite a few GPUs. Not just Pascal .
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8823239
Hmm only 1582? My 970 hits 1674 stable, not heavily oc'd at all.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8823367
HWmonitoring is useless when it comes to GPU frequency.
About pushing your card: most of the GTX 1070 cards are able to get 2100MHz on core. Not sure about memory, but on my founders edition I put +230MHz on core and +700MHz on memory. Stable 24/7.
But for starter go with +150 on core and +400 on memory. Then slowly rise up and hope for best results.
Let us know what can you get out of that card.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827412
what about voltage? do i touch that
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827416
In my case I was using EVGA PrecisionX, and I didn't touch voltage at all.
But if you have voltage option unlocked, try using +50mV or something like that.
WD My Cloud 4TB
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827424
2 minutes ago, josh_27 said:
mine is by % so im not sure how much mV to increase it by
As I know, GTX 1070 and 1080 have locked voltage anyway.
So card won't go above 1,09V.
Those cards could easily run on 1,15V 24/7, but are sadly locked.
What is your voltage at stock?
Try to use +10% and see how far it will get.
You are 100% safe to have it at 1,09V.
WD My Cloud 4TB
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827436
Its locked in Afterburner but not on gpu tweak. Im not quite sure about the voltage at stock but can i find it somewhere on gpuz? im looking at something called vddc and its at 0.8V with 20% boost in voltage
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827470
Yeah that's the voltage I'm talking about.
Now you just need to use valley benchmark in windowed mode, push everything to max settings and let it run. Keep an eye to that voltage and boost cloocks.
I get 1,05V on stock settings with founder card, but when I use precision X and push voltage to 100%, it goes to 1,062V. So not a big difference and it won't make any dammage on your GPU.
Not 100% sure why my card isn't going to 1,09V, but it seems like it doesn't need it to run on 2101MHz core clock and 2250MHz memory clock (showing in GPU-Z sensors).
I say you push it to max and you will see that it won't go higher than 1,09V.
WD My Cloud 4TB
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827486
alright thanks for the input! will try it out
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827488
No problem mate.
I think you can expect 2100MHz on core easy. Anything after that will be probbably unstable.
WD My Cloud 4TB
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827493
Go to Nvidia panel and choose on Power Maximum performance, this might be why its throttling.
//Case: Phanteks 400 TGE //Mobo: Asus x470-F Strix //CPU: R5 2600X //CPU Cooler: Corsair H100i v2 //RAM: G-Skill RGB 3200mhz //HDD: WD Caviar Black 1tb //SSD: Samsung 970 Evo 250Gb //GPU: GTX 1050 Ti //PSU: Seasonic MII EVO m2 520W
https://linustechtips.com/topic/687312-gtx-1070-not-boosting/#findComment-8827602
