6700k vs 5820k/6800k at same clockspeed
Solved by i_build_nanosuits,
Just now, Sahil10416 said:I agree, i didn't read the ques properly.
Well my answer is that it doesn't matter because both of these cpu's support hyperthreading & if you need more core power while playinf games on 6700k it would automatically split into more logical cores which will result in similar performance.
i gave him the correct answer already
no problem though...i would get the 6800K out of these personally but sometimes the 6700K is noticeably cheaper depending on the motherboard you get and if all you do is gaming then it'll perform better in most games because it has a higher IPC...if user is doing other stuff on the side then i would lean for a X99 build especially if money is not an issue.
