DAC/Amp for DT 990 Pro?
Meestagibbon
Looking to purchase Beyerdynamic DT 990 Pros the 250 ohm edition and I'm looking for a good DAC/headphone amp to hook up to my pc that will handle that level of power acceptably.
The DT990 Pros are pretty easy to drive, so your onboard solution can more than likely provide more than adequate power to them.
I would recommend you to atleast try the headphones with your onboard solution before throwing money at an amp/DAC solution.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
2 minutes ago, Volbet said:
The DT990 Pros are pretty easy to drive, so your onboard solution can more than likely provide more than adequate power to the.
^this
only get an amp if they don't get loud enough, which they should.
And only get a DAC if you have some kind of distortion in your onboard.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
What level of power? High impedance doesn't dictate that high power will be required.
Well thank you, this is what I needed to know, what impedance really meant. the power level isn't provided in the descriptions I've looked at so far but I'll keep looking and keep it in mind.
It's a function of impedance and sensitivity.
Hey man,
I have the Beyerdynamic DT 990 pro 250 ohm my self and drive them of my motherboard self! And have no issue's what so ever.
I think you dont need a dac or amp for these headphones.
1 minute ago, CebasvdH said:
Hey man,
Alright thank you so much!
No problem man! Have fun with the headphones! I love them
I'm actually in a hurry to order them as soon as I get paid because I want the limited editon all black ones xD but I will.
