Keychron K4 Pro
Solved by tomatensaftliebhaber027,
14 minutes ago, GarlicDeliverySystem said:Keychron's website has them with K Pro Blue switches.
Otherwise, if you have a bit of time and don't mind the work, the K4 Pro has hotswap sockets. You could just buy blue/clicky switches of your liking and exchange whatever switches are in the one you found.
Yes, thanks a lot, but I need the German layout. I will probably just replace the switches with Gateron Blues.
