Ultimate Cooling Machine -- Heavily Modified TJ07 [Not 56k friendly]
deafboy
Hey Guys,
Been asked to post this over here so I figured why not.  So this build has been in the works for just under a year.  After all said and done things could have been started and finished in under a week but there was certainly a lot of trial and error over the year, that in conjunction with taking my time and keeping busy with school it took longer than expected.  The past two months of the build were pretty much me waiting on people (welders/powder-coaters/etc) to get their part done
[introduction and plan]
This was essentially my dream build and decided to treat it as such, although the GPUs will likely be upgraded in the spring.
The TJ07 has been around for a long time and is certainly showing it's age and I love the case enough but want a refresh. I plan on replacing and modifying 100% of the panels while maintaining the same essence of the TJ07. Primary upgrades:
8-slot I/O panel to support quad GPUs
Create better fitting doors and panels
Support for 8.120 Rad space
Keep it a classy, quiet, and high performing machine.
This machine is an all around work-horse (programming, folding, gaming, multimedia, and of course the interwebs)
The bottom section of the case houses the AX1200i, pump, EX480 and EX120.
Up front is an EX360, reservoir, and fan controller.
In addition to being heavily watercooled, hard pipe has been used with copper tubing, although it's been painted to fit the look of the build
[current parts list]
-Silverstone TJ07
-ASUS Rampage IV Extreme
-Intel 3930k @4.8-5.2GHz
-Corsair Dominator Platinum 1866
-2x EVGA GTX670 FTW @1400+ on the cores
-ASUS Xonar DX
-Crucial M4 256GB SSD
-Western Digital Caviar Black 2TB
-Corsair AX1200i w/sleeved cables
-Dell 3007wfp IPS Monitor
-2x Dell 2007fp IPS Monitor
-2x 4TB Hitatchi USB 3.0 External Drives
-Corsair SP2500
-Sennheiser HD280
-Koolance PMP-500 Water Pump
-EK 250ml Advanced Reservoir
-XSPC Rampage IV Extreme Water Block
-XSPC Raystorm CPU Waterblock
-2x XSPC GTX680 v2 Waterblocks
-XSPC EX480 Radiator
-XSPC EX360 Radiator
-XSPC EX120 Radiator
-Lamptron FC-5V2 Fan Controller
-Scythe S-Flex F 120mm Fans (Until I find something better)
-copper tubing
-push fittings
-a bunch of aluminum sheeting for fabrication
Not really a huge fan of the name, but it is what it is now... although I'll likely go phase at some point, lol.
I am not going to copy the entire build log here, figured I'd at least show you guys the semi-final result though.  If you want to check out the entire build log please check it out here:
Semi-Final Pics:
Random Progression Pics:
3930k | RIVBE | 32GB Dominator Plat. | Titan XP | Intel 750 1.6TB | Mellanox 10Gb NIC | AX1200i
Custom TJ07 | 2xD5 pumps | EK Supremacy EVO | EK Titan XP | EK RIVBE Block | Cu Tubing | 25x120mm Rad
Samsung U28D590D 4K | Leopold Otaku w/Browns | Corsair M65 | Corsair SP2500 | Sennheiser HD595
amazing
| 3570k @ 4.5 | swiftech h220 ordered after patent issues | EVGA 660ti SC 3gb | 8gb gskill ripjaws | Asus p8z77-v lx | Corsair Ax 750 | Asus Xonar DS | Corsair C70 white | CM quickfire rapid mx browns | G500 |
I Remember following this build religiously when the sever was using Vbulletin but when the sever was changed I lost it :(
I am amazed at how epic this has become and how much it has changed since I last saw it. You sir are a machine!
Your work is amazing keep it up! :D
The first step to insanity is believing in your sanity.
looking good so far
in my basement,using a computer,staring at a 1024x768 screen
Because it's needed. lol.  Thanks, Slick for the wallpaper.
That's so freaking sexy :o
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
Amasing bulid
Case: NZXT Phantom 410 Cpu: i7 3820 at 4.3 Ghz Motherboard: Gigabyte GA-X79-UP4 | Gpu: XFX hd 7970 Ghz 1100Mhz/1600Mhz Ram: Crucial BallistiX Elite 16GB 2x8 Gb 1866 Mhz
SSD's: 2x Kingston HyperX 3K SSD 120 GB in RAID 0 HDD:Seagate Barracuda 2TB 7200 Rpm
Cpu cooler: Corsair H100i with SP120's | Psu: Corsair TX 850W My monitors: 3x BenQ 24"  GL2460 = Eyefinity
looks nice
Thank you :)
amazing
Thank you :)
I've made it through
Haha, thanks.
Yeah, it was kind of nice that it got taken down though, allowed me to complete it and do a more concise thread.
Thanks! :)
looking good so far
Thanks
very very nice
Thank you
why windows 8?? and 1400+mhz on both 670's? that's hard to believe lol whats ur temps or is that just for benching..
I like Windows 8... I never touch metro so it's been a nice bump.
The temps are generally in the 50s under load at 1400+, but I've seen it in the 60s when I did a long session of intense loads.  I generally just leave the clocks lower though since I only game on the single monitor, have yet to find anything that I play that requires more of an overclock.
The top card on stock volts did 1350 and the bottom one did 1325.  Flashed the bios to up the voltage and am perfectly stable at 1400+ on both of them with the bump.  Honestly though, it's almost pointless.  The performance increase from 1325-1350 to 1400 is pretty much nonexistant outside of benches.  I went to 1420 or so on the top card during benches and was disappointed by the gains so I dropped it back down.  The added volts certainly bump the temps and power usage.
Thanks
Amasing bulid
Thank you
THAT CASELABS ! Any information about it?  :)
Friends build that I was holding onto while he was away
any build log about the caselab?
There is one over on OCN but it's pretty much an endless pit.  It's going to be shipped across country soon and will get a pedestal and stuff thrown onto it.  Constant never ending project.
There is an SR-2, Lepa 1600, bunch of water cooling gear, chillers, and soon to be some 9000 series GPUs
Thats amazing! I've always wanted to do a build with that case but I don't have time and craftsmanship.
rawr!! I'm a ferret!
Haha, true that. Last time I checked it was well over 5000 posts long. Good thing
there's a table of contents, otherwise that log would just be completely unreadable. :lol:
Ontopic: Good to see this here. IIRC I gave a vote for MOTM for this baby. :)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
very nice build :)
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
wow.... clean is clean!
amazing!
-Corsair Carbide 500r + TX-750w V2 | Asus P5Q Deluxe + Intel Core2Duo E8400 @ 3.8Ghz + 2x2GB G.Skill DDR2 1066mhz
-Sapphire HD4890 1GB DDR5 (New Edition) + 1x Intel SSD 330 120GB + 2x Seagate Barracuda 500GB SlimSinglePlate (RAID0)
Wow.  Really good job.
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
Wow, that looks absolutely gorgeous, Build of the week material for sure.
looks amazing dude! some neat metal work going on here
Thanks, and you can definitely do it just have to spread out your time.  I didn't have much time, that partially why it took me as long as it did.
Haha, yeah, it's pretty much impossible to follow over there.  Always something changing.  And thank you :)
I want to upgrade to win8 sometime soon but 7 works great so far. Only reason is cos of DirectX11.2 hate the lack of Aero on win8 but I think there are mods for that. Sigh* already installed 7 on my 840 Pro lol
Honestly, there isn't much of a reason to upgrade, it's certainly lighter and there are some nice new features but nothing mind blowing.
very nice build :)
Thank you :)
amazing!
Thank you for the kind words :)
Haha, thanks...lol, that gif gets me everytime
Thank you.
