[Question] Bitspower Fittings 3/8" x 1/2" - Tubing won't come off
Solved by Lays,
Also, what do you guys suggest about the compression not screwing on the threads of the barb? It's pretty much stuck, I can't get the thing undone on either end. Please see the attached image for example.. It doesn't want to come off!
Do you have any pliers?
If you take your shirt, and wrap it around it then grab some pliers you can usually get em off.
The shirt is for traction + not scraping the shit out of the fittings
( Towels work too)
