ON MY WAY TO BUY A CPU COOLER NEED YOUR OPINION
Solved by FairladyZ,
thanks for the quick reply #djdwosk97
should i replace the evo fan with a noctua or just use one of the corsair AF series 120mm i got a spare one http://www.newegg.ca/Product/Product.aspx?Item=N82E16835181023
AF and SP fans sound like jet engines...don't use them...Noctua NF-F12 is super quiet and moves a ton of air. look into those. They're expensive though..
And now my suggestion for the cooler..
Keep the Hyper 212 Evo until you decide to get into water cooling. Hyper 212 is a great cooler, and 4790k will perform just fine with it.
