game zero need amps or sound card?
Solved by cjtaxi,
Audio passthrough from cheap-middle end speakers are usually not well built and could introduce noises. Case per case of course. It's better to go straight to the source.
Anyway, just try them all. If you can't hear a difference, then there's no difference.
ah hmmm ok ok thx for your suggestion...
Featured Topics
Gat Pelsinger ·
Posted in Programming0 -
GanjajoggiBig ·
Posted in Servers, NAS, and Home Lab5 -
Quackers101 ·
Posted in Windows1 -
ECZxEMMA ·
Posted in Troubleshooting0 -
Fio ·
Posted in Networking3 -
Nervoussoup101 ·
2
19
2
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
