Did anyone else even know that these exist? Sorry if this seems like kind of a dumb post i just thought this was pretty cool. Besides government facilities, who would even need something like this on a scale that would justify the purchase?
Just a normal guy with a constant desire to modify everything he owns.
Check out my current build here:
https://linustechtips.com/main/topic/1006447-the-cake-is-a-lie-water-cooled-portal-pc/
https://linustechtips.com/topic/348293-hard-drive-shredder/
This is a metal shredding machine to compact and recycles any metal
this is not specifically made for hard drives
there are crushers made to destroy hard drives with sensitive data and they look like this
you dont buy a $10000 machine to crush hard drives
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740849
Oh ok. Well that makes more sense to me. I was trying to figure out why someone would buy such a big expensive machine just to destroy hard drives unless it was like the CIA or something.
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740863
I just chuck my hard drives at a wall.
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740923
no I would pay the goverment $1 for every HDD and take the magnets
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740928
My work uses a machine similar to this to destroy old hard drives with sensitive data.
An organisation isn't going to want to tender out machines and have some random buyer logon to their domain/accessing the data
Scrapyard Build Total Cost: $268AUD
C2Q E8200 | 4 x 1gb DDR2 | GA-EP45-DS3 r1 | Gammax 200 | 320gb 2.5" | 7870LE PCS | Litepower 500w | CISCO Aironet 350
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740941
This is all just way too sad.   :c
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740948
If you want to wipe and HDD completely, why not just hammer it?
Or microwave it?
I'm sure you could pull off some of the data if you wanted to, even after smashing the platters to bits.
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4740961
I knew these existed, but never saw the point... If the drive still works, I run a secure write software. If the drive doesn't work, I can just as well take it apart and smash the platters... Or make a cup coaster out of it
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4741003
exactly my point. who the hell has this kind of volume that they need a huge ass expensive machine dedicated just to destroying hard drives. unless you're an electronic recycling plant or the CIA or something.
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4741015
I open up drives and run my knife over top of the platters, moving the knife slowly from the center to the outer edge. If there are multiple platters or data is stored on both sides, I flip the disk, and do the same. Just for safe measure, I usually run a sharpie over top of them too. After all that, I'll bend or cut through the platters with a pair of sheet metal shears/snips. All depends on the mood I'm in, or the tools at my disposal.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4741076
Wouldn't the shock causes the magnetic...polarity?... to change or something?
Anyway the point with physically obliterating hard drive is to make it clear, even to a jury, that nothing could have possibly been recovered. sometimes a lot of people feel that the'll be framed by "experts" testifying that the uncovered x and y, so grinding a disk into dust is the best way to prevent that.
Jake's paranoid data protection steps-
Dban like 30 passes
open, fire up platters, hit with hammer while in plastic tub to catch the little bits- when the drive is spinning at 5400 or 7200 rpm it is really easy to shatter
pound it into dust
throw dust over various parts of a lake.
Add fire in this process where you feel needed.
Each one of the steps I included have all individually been used to make data not recoverable to forensic teams in a criminal investigation. Even drives that were not shattered but were water soaked long enough (few years?) were not workable
Disclaimer- This amount of excessive hard drive destruction makes you look guilty of something.
SSDs-
Dban a few passes, take pcb out, put in Blender, spread in lake.
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4741855
There was a story I came across a number of years ago where for an RMA on a hard drive from a police department, the manufacturer made the... mistake of saying they'd take the hard drive back in any condition. They let a few officers take some shots at it.... literally. Trying to find the story but can't remember where I last saw it...
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/348293-hard-drive-shredder/#findComment-4748695
